Author Topic: removing filco logo  (Read 1652 times)
Offline godofdeath
removing filco logo
« on: Thu, 25 August 2011, 07:28:59 »
How do you remove the filco logo?
is it glued on or clipped on from behind? How do you take it off?????????
Offline Henry Allen Venture
removing filco logo
« Reply #1 on: Thu, 25 August 2011, 10:12:05 »
Quote from: godofdeath;404801
It looks recessed, so you might be able to prize it out if you have a thin/sharp but, strong enough knife.
There's probably some kind of clip or glue on the back that'd make it difficult, though.
Out of interest, what do you want it out for?
I honestly don't know why you'd want to remove it, unless you were going to paint the frame and put it back. They look really nice.
Current collection:
Filco Majestouch 104-Key, w/ MX Browns
IBM Model M 52G9700
Leopold FC200R, "white" w/ MX Clears
Ducky DK9008S \'Shining\', white backlit w/ MX Blues
Cherry G80-3494(LCYUS-2), w/ MX Reds for Portal Mod
Not mine, but I\'ve got access to:
Filco Majestouch Linear R Limited Edition, w/ MX Reds
Filco Majestouch 2 \'Ninja\' Tenkeyless, w/ MX Blues
Leopold FC500R, w/ MX Browns
