Author Topic: Das Multimedia Keys  (Read 2077 times)
Offline nolliepoper
Das Multimedia Keys
« on: Sat, 27 August 2011, 00:30:09 »
I read that the Das silent model S keyboards with Cherry MX Browns have multimedia keys.
Does anyone know how to use them? I read it may have to do with using the left windows key as a modifier to the F keys.
Filco MJ2 TKL (Brown)
¯\\_(ツ)_/¯
Offline Arcanius
  • Buckling Spring Lover
Das Multimedia Keys
« Reply #1 on: Sat, 27 August 2011, 12:03:59 »
That is false.
The Das S keyboards used to have muiltimedia keys on F5-F9, but that didn't last very long, and currently shipping models don't have them anymore
Offline Arcanius
Das Multimedia Keys
« Reply #2 on: Sat, 27 August 2011, 12:59:15 »
I wasn't trying to be rude about it, sorry! Tone is hard to portray in writing. That's why I'm not the next Oscar Wilde. Noodles256 is the rude one! :) Welcome to geekhack, just noticed it's your first post!
Offline Arcanius
Das Multimedia Keys
« Reply #3 on: Sat, 27 August 2011, 13:04:40 »
So in the end was I rude about it or not?:behindsofa:
The Das multimedia keys were a topic of discussion a good while back, it's good to be clear about true or false statements.
Offline nolliepoper
Das Multimedia Keys
« Reply #4 on: Sat, 27 August 2011, 14:25:23 »
Quote from: ripster;406029
Uh, Welcome to Geekhack.  Arcanius is correct but a bit rude about it.
You can AutoHotkey those functions in a variety of ways.
I knew you would reply with a autohotkey suggestion. There is nothing wrong with using ahk but I would rather avoid it running ahk while playing star2 because it has the capability of performing more than one action, bind to one hotkey.
Nonetheless, while using your ahk script, I notice the volume tooltip but it does not modify my volume at all.
¯\\_(ツ)_/¯
Offline slueth
Das Multimedia Keys
« Reply #5 on: Sat, 27 August 2011, 16:13:31 »
Hah Ripster likes ducky now :D. Glad to see you in the forums nollie.
Offline nolliepoper
Das Multimedia Keys
« Reply #6 on: Sat, 27 August 2011, 16:57:53 »
I won't be getting the Ducky Shine because I just bought my Das and the Ducky Shine uses Cherry MX Blacks.
Setting aside gaming and other keyboards, is there a working AHK script I can use to modify my volume?
I got the AHK script, ripster was working on, somewhat working using "Send {Volume_Up}" and "Send {Volume_Down}".
Source: autohotkey.com/docs/commands/SoundSet.htm
¯\\_(ツ)_/¯
Offline kpeezy
Das Multimedia Keys
« Reply #7 on: Sat, 27 August 2011, 17:57:44 »
What are you actually trying to do? Do you want to control all sound output or just something specific? I use foobar2000 for my media player and I use custom foobar hotkeys to adjust the music volume while in game.
Let's actually help instead of giving out nonworking AHK scripts (no matter how proud of them Ripster is).
edit: and it should be obvious to anyone with a low level English vocabulary that the first response is not rude in any way.
« Last Edit: Sat, 27 August 2011, 18:00:47 by kpeezy »
Offline The Solutor
Das Multimedia Keys
« Reply #8 on: Sat, 27 August 2011, 19:25:43 »
Quote from: nolliepoper;406133
I suggest you to use volumouse (+ optional 3vx to have the OSD), emulating a volume knob with the mouse wheel is way better than messing with AHK
« Last Edit: Sat, 27 August 2011, 19:36:04 by The Solutor »
Offline nolliepoper
Das Multimedia Keys
« Reply #9 on: Sat, 27 August 2011, 22:52:19 »
Quote from: kpeezy;406143
I was original asking how to use the Das multimedia keys and it turned out they discontinued their keyboards that replaced the left windows key to a function key for multimedia F keys.
So, I decided to test out ripster's AHK script and it turned out to not work for me. Then I made a few minor tweaks and stole his tooltip idea, thanks for the idea.
I came up with this.
Code: [Select]
b = 0
Send {Volume_Up}
Tooltip, Vol: Up
SetTimer, RemoveToolTip, 2000
return
Send {Volume_Down}
Tooltip, Vol: Down
return
Send {Volume_Mute}
if(b = 1)
Tooltip, Vol: On
b = 0
else
Tooltip, Vol: Off
b = 1
return
RemoveToolTip:
SetTimer, RemoveToolTip, Off
ToolTip
return
After that was all said and done, I may end up checking out The Solutor's volumouse program it seems like a simple concept to modifying my volume.
¯\\_(ツ)_/¯
