Author Topic: Mod III: IBM Model M On-Key Caps Lock Indicator  (Read 7845 times)
Offline wcass
« on: Sat, 27 August 2011, 22:37:16 »
This is the third installment of a series I am doing on modifying an IBM Model M. The plan and key layout is discussed here. To sum it up the project so far, I started with an IBM 122 key terminal and cut off the numeric and directional keys to bring the total keyboard width to 15 inches which is about the same as the original IBM Space Saving Keyboard. You can read about that mod here.
  I’ve always liked on-key Caps Lock lights and have wanted this with my preferred key type – buckling spring. So while planning a bolt mod, I noticed that there is a stud under the Caps Lock key. This is true for all three of my 1391401 and my modified 1394100 terminal. I came up with the idea to drill this stud out, run a wire up the hole, and mount an LED there. But this would tie the back plate, membranes, and barrel plate together making disassembly difficult. I started looking up what was available in LEDs at Digi-Key and came across light pipes and surface mount  LEDs. I bought several sizes and types of light pipes and LEDs to test. The Bivar light pipes I ordered worked perfectly. I’m using two in this example - you might choose to use one, but order two or three for a few extra pennies.
    [ Guests cannot view attachments ] 25160[/ATTACH]
The surface mount  LEDs that I ordered from Digi-Key might have worked, but were too small for me to solder leads to. Fortunately, I was able to find some pre-wired by Miniatronics. My local hobby shop did not have them in stock, but they ordered them for me. They come with resistors, four to a package, in red, blue, or yellow. I ordered blue, so have three extra that I might give away or trade (anyone plan on doing red?).
    [ Guests cannot view attachments ] 25161[/ATTACH]
  I used a .125” drill bit to drill out the stud. The 3mm Bivar light pipe fits snugly. I cut off the two micro-studs on the light pipe and used a drop of hot glue to set the LED. I added a 75 ohm resistor to the end of the red lead and extended both leads another 12 inches to the Teensy. Thanks Soarer.
  [ Guests cannot view attachments ] 25162[/ATTACH]
[ Guests cannot view attachments ] 25163[/ATTACH]
[ Guests cannot view attachments ] 25165[/ATTACH]
  The VLP-550-F light pipe protrudes 4.5mm out from the top of the barrel plate.
  [ Guests cannot view attachments ] 25166[/ATTACH]
[ Guests cannot view attachments ] 25167[/ATTACH]
[ Guests cannot view attachments ] 25168[/ATTACH]
    If I had used a rounded top light pipe like the VLP-450-R there would be even more light spilling out from behind the key. I drilled a .125” hole in the top left corner of the Caps Lock key and glued another light pipe to the key to see how that looks. I like it best, but decide for yourself if you prefer back-lit or front-lit Caps Lock key indicator.
  [ Guests cannot view attachments ] 25169[/ATTACH]
[ Guests cannot view attachments ] 25170[/ATTACH]
  [ Guests cannot view attachments ] 25171[/ATTACH]
  These pictures were taken with a flash so the light appears less noticeable than it really is.
Offline Oqsy
« Reply #1 on: Sat, 27 August 2011, 23:12:06 »
Great stuff!  If you decide to keep the front-lit version, i would opacify the light pipes with a bit of paint or electical tape over the verical bits to minimize the spill of light behind the right side of the key cap, so that the light getting through the tube is all you can see. :D
Thumbs up for a great and well executed mod!
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline wcass
« Reply #2 on: Sat, 27 August 2011, 23:16:28 »
thanks, that's a great idea.
