Author Topic: PC keyboard with the same keys used in Apple's MB110?  (Read 1329 times)
Offline ibu
« on: Sun, 28 August 2011, 02:59:15 »
I like the typing with an Apple MB110 keyboard.
Because there's no way to get it work with my computer and Win 7 (there's a long thread about that without success) I like to look for a keyboard for PCs which uses the same keys.
I prefer a design which is minimalistic and where the case is made of metal.
Any hints, suggestions?
Thanks.
Offline The Solutor
« Reply #1 on: Sun, 28 August 2011, 08:47:33 »
BTC has a couple of models.
But at the moment their site is down so I can't be more precise.
