Author Topic: Model m sprint  (Read 1274 times)
Offline bavman
Model m sprint
« on: Mon, 29 August 2011, 16:17:20 »
How do i get a spring back in the keyboard so it works right? I cant really see whats going on in that deep well. Do i need to take the bottom off so its easier?
p.s. ignore the typo in the thread title, its supposed to say spring
Offline Ascaii
Model m sprint
« Reply #1 on: Mon, 29 August 2011, 16:57:23 »
If you open it you will need to do a full bolt mod, which i dont think you want to.
The easier way is the sandy55 chopstick o death method. just search for it in the gh search
Offline bavman
Model m sprint
« Reply #2 on: Mon, 29 August 2011, 17:11:36 »
Sweet thanks, I'll try that.
