Author Topic: whats a good mouse pad?  (Read 9608 times)
Offline Gravediggaz
« on: Tue, 30 August 2011, 01:44:14 »
hey guys looking for a good mouse pad for my razer deathadder....something that glides smoothly
thanks all
Offline kywirelessguy
« Reply #1 on: Tue, 30 August 2011, 09:51:31 »
Do you prefer fabric or plastic? Do you like soft or hard? Do you want hugemongous or itty bitty?
I'm using a Razer Goliathus. I prefer big, flexible, cloth.
My previous pad was an Xtrac.
I would recommend some mouse feet things to go with the new pad. For about $4
Offline Vocroth
« Reply #2 on: Tue, 30 August 2011, 10:04:48 »
i have a steelseries qck+ heavy, and i love it so far
my previous pad was a razer destructor
Offline Chobopants
« Reply #3 on: Tue, 30 August 2011, 10:26:56 »
I have both an original Icemat and a Steelseries I-2 (what SS made after they bought Icemat). I love them! I've used an eXactMat and some other gaming pads before but nothing beats the frosted glass feel of the I-2 for me. If you like a REALLY smooth glide (I mean REALLY smooth) the I-2 is for you. Many people like the friction of rougher pads but not me. :)
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline ZeroGraVT
« Reply #4 on: Tue, 30 August 2011, 10:47:28 »
I just got the deathadder black edition with the goliathus control mouse pad.  Works well together and the pad is very very smooth.
Offline vun
  • Just one more thing
« Reply #5 on: Tue, 30 August 2011, 11:05:38 »
Quote from: Chobopants;407410
Did SS buy IceMat? From what I read they were two brands under one owner who were launched simultaneously, but later merged. At least that's what I gathered from it, a bit hard to understand it all.
Also, +1 for the Icemat(it will always be icemat for me), it is absolutely fantastic and the best surface I have used so far.
Only issues I have with it are height and sound. Sometimes it feels a bit too high to be used comfortably, but that might vary depending on how you sit.
Other issue is sound and feel; it feels like it's eating the mouse feet. I've heard it's actually rather gentle with the feet, but it just doesn't feel that way.
A third issue some might have is cleaning; it's important to keep it clean.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Tue, 30 August 2011, 11:47:17 »
Artisan Shiden-Kai mid. It's a glass coated cloth pad. It has the glide smoothness of a hard surface, with a soft feel of cloth with slight friction and offers the best tracking of any surface I have tried to date.
Offline arplod
« Reply #7 on: Tue, 30 August 2011, 12:38:14 »
Quote from: lysol;407476
Very interesting. Any pix of a well-used pad? I also don't quite get how a glass coat on a flexible substrate works - user's impressions?
I use a variety of Razer - mostly rigid - pads.  They work for me but hahahaha not always well with Razer mice.
Offline Chobopants
« Reply #8 on: Tue, 30 August 2011, 14:29:20 »
Quote from: vun;407443
Ah I don't know, always assumed SS bought Icemat. I was so sad when I saw there weren't anymore Icemats, thankfully we can still get I-2s.
It's definitely a high maintenance pad. I cover mine when it's not in use with a handkerchief and regularly clean it off with some water and a towel. If there's ANY dust on it theres a lot of noise and scraping. However, it's totally worth it for that smoooooooooooooooooooooth glide. Love these things.
Offline Chobopants
« Reply #9 on: Tue, 30 August 2011, 14:30:57 »
Here's a pic of my original Icemat. Had this guy for at least 6-7 years now!
Offline vun
« Reply #10 on: Tue, 30 August 2011, 15:19:07 »
Quote from: Chobopants;407589
I thought the same, but when I decided to find out more it seemed like they were two different brands under the same owner that were later merged into one. I still have a Siberia with the IceMat logo, but never got around the getting an actual mat before the merge. Still, the I-2 is supposed to be exactly the same mat, just under another name.
Offline Mazora
« Reply #11 on: Tue, 30 August 2011, 15:34:00 »
hu... this is CRAZY GOOD: http://www.cshyde.com/c4web/home.htm
i've tried em all, and I settled on the cshyde for good..(Xai at the moment). It's SOOOOOOO Good.
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline Chobopants
« Reply #12 on: Tue, 30 August 2011, 16:23:04 »
Oh that's pretty cool Mazora, I might try that out some time. :)
@vun yeah it feels identical, though the I-2 is a little bigger. At 900dpi I really don't need that big of a pad but its nice because I'm guaranteed to never get near an edge.
Offline munch
« Reply #13 on: Tue, 30 August 2011, 20:47:08 »
I'm definitely going to agree here - I have tried all the Razer, Corepad, Steelseries, Everglide and QPad cloth pads and none even come close to feel and quality. (well perhaps the Razer Goliathus Speed on its first week, it really wears out a bit too fast)
I have owned an Artisan KAI.Hien G3 Hard, Soft and the Shiden MID (the white normal version) and had each for over 6 months. They have been put under a lot of stress and I play a lot of competitive high level gaming with a not too high sensitivity. Not much sign of wear, I only needed to wipe them off with a wet piece of fabric (do not use paper, it's kinda weird - breaks up and sticks to the mousepad) if they had just a little bit of inconsistency.
Well those are my 2 cents, but it's a relatively expensive piece of cloth - though worth every penny.
Offline TOZZIL
« Reply #14 on: Wed, 31 August 2011, 07:56:54 »
As I am a mid sense gamer and wanted a long-lasting and cheap mousepad I went with the raptor gaming p5.
Big enough for me, easy to clean and almost indestructible.
[SIGPIC][/SIGPIC] Raptor Gaming K1 with GhettoReds
Offline Bilbin
« Reply #15 on: Wed, 31 August 2011, 12:26:19 »
PureTrak Talent, read the reviews on google.
Filco Majestouch Tenkeyless Blues - Razer Abyssus - PureTrak Talent
Offline Arc'xer
« Reply #16 on: Wed, 31 August 2011, 12:36:27 »
Quote from: arpod;407527
Shiden-kai. And Shiden(white color unlike the red -kai).
Offline Tennobanzai
« Reply #17 on: Wed, 31 August 2011, 13:54:46 »
I've had the Razer destrutor for about 1 year. It's decent but it's finally showing some wear
Offline Mazora
« Reply #18 on: Wed, 31 August 2011, 14:22:07 »
Yeah the OP doesnt seem to be interested in a mousepad - mouse combo but rather asking for great quality mousepads (or great for the buck).
RF-87UW
Offline arplod
« Reply #19 on: Wed, 31 August 2011, 15:10:16 »
Quote from: Arc'xer;408154
A Twilight mouse pad? Jesus.
Offline nolliepoper
« Reply #20 on: Wed, 31 August 2011, 15:34:13 »
At first I was hesitant before buying a gaming mouse pad but I went with the Razer Kubuto soft mouse pad which is considerable small for gaming pads.
I have been pretty happy so far with the Razer Kubuto. It really does have more quality than a cheap overpriced gaming pad I first thought I was buying.
Filco MJ2 TKL (Brown)
¯\\_(ツ)_/¯
Offline Lenny_Nero
« Reply #21 on: Thu, 01 September 2011, 03:44:04 »
Quote from: Vocroth;407390
i have a steelseries qck ...
I have an SS qck 'something, about a foot square rubber backed cloth.
Not going to be using anything else. For the cost I have not seen/used anything that can come close.
But then I am not a gamer and just use the mat to help the  mouse track better and feel smooth,
adds nothing to my street cred or hi score.
YMMV
Filco Zero, Viglen DFK 2020UKF104, DTK SPK-102a, Panasonic Biz 500
Ducky 1087,  Chicony KB-5191, G80-1856HQMGB Cherry G80-1000HFD and others
 G80-11908HRMIT, Tipro MID-KM128a, Access AKEOXPB312/2 (20x7), Access AKEOCTI635/1(15x6)
Offline Gunny
« Reply #22 on: Thu, 01 September 2011, 04:11:39 »
Saddleback Leather mousepad. Feels great, looks great and will outlive me without any doubt. I will never need another mousepad.
Offline NewbieOneKenobi
« Reply #23 on: Thu, 01 September 2011, 09:15:38 »
I have Goliathus Speed. I eat off it, wash it with washing powder and abuse it in all sorts of ways. It even has cat fur all over.
Best mouse and pad combo I've ever had, however, was a cheap Logitech issue (EX 110 wireless desktop, wasn't cheap back then but the mouse's price was influenced by wireless being pricey at that time) on a small, scratchy round pad that I bought in a museum in Greece (the round shape to resemble the disk with linear writing that was depicted on it). The mouse received a layer or two of tiny teflon sliders. The only problem was the pad being a bit too small and the sliders colliding with edges. Otherwise it glided like on ice. But that was in 1024*768, when 800 dpi was plenty.
By the way, Gunny's leather pad absolutely rocks and I mean it. Must be the cavalryman's blood.
However, some really good pads belong to the cheapest pads ever, as in pads that don't even get a print on them to cut the costs. Like $1.5 pads. Almost as good as my Goliathus, although not there (too much friction, slower gliding, theoretically better for some kind of games or gamers, though).
Some other great mousepad I've had has been the kind some guy from the Internet would print custom pictures on. It cost half of what my Goliathus did and might have been better. But it was for a gift. I didn't order another. I may be ordering some for Christmas for my customers (to put my company contact data on it, basically, as in passive advertising) and I may keep one or two for me then. You may want to try too. As a bonus, you can print your gaming alias or something on it.
IMHO the ultimate gliding comfort is the product of the pad, the mouse sliders (and possibly the size of the sliding area) and the weight settings of the mouse (the removable weights).
« Last Edit: Thu, 01 September 2011, 09:22:25 by NewbieOneKenobi »
