Author Topic: Changing switches of Razer BlackWidow Ultimate original  (Read 25246 times)
Offline elo820
« on: Wed, 31 August 2011, 03:39:13 »
hey guys,
I was wondering if it was possible to switch to brown cherry if possible? If so, Where could i buy browns?
Thanks in advance guys.
Offline slueth
« Reply #1 on: Wed, 31 August 2011, 03:45:25 »
there is a new version
of the razer that comes with browns..
marketing term stealth.
Offline elo820
« Reply #2 on: Wed, 31 August 2011, 13:14:28 »
problem is that I have the original. I dont plan on spending another 140 bucks =p. Anyone?
Offline noodles256
  • le legendary
« Reply #3 on: Wed, 31 August 2011, 13:16:49 »
ninja
AF | Ducky YOTD |
Offline Lanx
« Reply #4 on: Wed, 31 August 2011, 13:31:43 »
find a cheap brown switch donor board on ebay, imo, is the black widow plate mounted? (i'm pretty sure it is) you're gonna have to desolder.
Offline Arcanius
  • Buckling Spring Lover
« Reply #5 on: Wed, 31 August 2011, 13:35:26 »
Yeah, it's plate mounted, you can get brown switches from some Cherry G80-8xxx series boards, rawko may still have some on ebay. You'll have to desolder the switches from the BW, pop the top part of the switch off, pop the switches from the Cherry board (no desoldering on that one) replace stems, resolder switches on the blackwidow.
That's the cheapest way to do it, as buying browns would cost about a dollar a switch, and the BW has 109 switches, if I remember correctly.
Offline elo820
« Reply #6 on: Wed, 31 August 2011, 14:09:01 »
So I can't just pry them off? Desolder the plastic part? I saw some vids on youtube and they would just use a screwdriver. Thanks for all the tips guys
Offline elo820
« Reply #7 on: Wed, 31 August 2011, 14:10:15 »
Quote from: Lanx;408183
Can you link me to it? I cant seem to find them. all I see are ones that cost 150
Offline Arcanius
« Reply #8 on: Wed, 31 August 2011, 14:16:03 »
This seller had them, but the link is only for a board with clears, he used to have boards with browns, seems he's run out. Sorry!
http://www.ebay.com/itm/Cherry-MX-8000-POS-card-swipe-keyboard-PS2-WHITE-SWITCH-/330590827681?pt=PCA_Mice_Trackballs&hash=item4cf8bfb4a1
This one may have browns, there's no way to know unless you ask the seller!
http://www.ebay.com/itm/Cherry-POS-PS2-Keyboard-w-Credit-Card-Swiper-mx8000-BLK-/370532038896?pt=LH_DefaultDomain_0&hash=item56456e38f0
Also, a Compaq 11800 will work, but you won't have enough browns for the entire BW, you'll be about 8 short. (2 Win keys, FN key, 5 macro keys)
http://www.ebay.com/itm/Compaq-11800-Keyboard-w-Cherry-MX-brown-switches-PS2-/260830840798?pt=PCA_Mice_Trackballs&hash=item3cbabac7de
No, you can't pry them off with a screwdriver on a plate-mounted board, only on a PCB-mounted one. The cherries above are all PCB-mounted, but Filco, PLU, Ducky, Leopold, Razer, Noppoo, Das, Rosewill, and some others plate-mount.
« Last Edit: Wed, 31 August 2011, 14:23:38 by Arcanius »
Offline elo820
« Reply #9 on: Wed, 31 August 2011, 14:26:59 »
Wow Thanks! Now i just need to know how i can do this. Soldering seems a big job. Is it because of the LED? All i wanted changed are acutually the buttons on the main side. Letters , numbers , enter, space, etc. Dont really mind the Fn or numpad.
Offline noodles256
  • le legendary
« Reply #10 on: Wed, 31 August 2011, 14:29:45 »
soldering is easy. just put your keyboard in the dishwasher
AF | Ducky YOTD |
Offline Lanx
« Reply #11 on: Wed, 31 August 2011, 14:31:52 »
no it's cuz of the plate mounting.
while plate mounting seems to give more heft and stability to switches, it also covers up the switches as well. think of plate mounting as a sweater, you really can't take off a t-shirt unless you first remove the sweater. or in this case by desoldering you can "squeeze" the switches out of the sweater through the neck.
Offline elo820
« Reply #12 on: Wed, 31 August 2011, 14:40:20 »
I am looking at it the switches, but i do not see where i am supposed to solder anything?
Offline noodles256
  • le legendary
« Reply #13 on: Wed, 31 August 2011, 14:41:11 »
dishwasher first
AF | Ducky YOTD |
Offline The Solutor
« Reply #14 on: Wed, 31 August 2011, 14:51:30 »
Quote from: elo820;407928
hey guys,
Simple but not quick, due to the leds.
Take in account at least 5/6h of work, especially if you don't have a decent desolder and/or  little/no skill with soldering
http://geekhack.org/showthread.php?17357-U9BL-Beige-edition-(clear-switches-brown-springs)&highlight=beige+edition
Offline Lanx
« Reply #15 on: Wed, 31 August 2011, 14:55:56 »
you have to open up the whole board and de-solder from the back/bottom, then the switches will pop right out.
and of course you'll have to resolder, when i just resoldered an entire board took me 2hrs? or basically 2 episodes of reality tv.
Offline elo820
« Reply #16 on: Wed, 31 August 2011, 14:57:15 »
Offline elo820
« Reply #17 on: Wed, 31 August 2011, 15:05:11 »
Offline noodles256
  • le legendary
« Reply #18 on: Wed, 31 August 2011, 15:10:24 »
dishwasher wow
AF | Ducky YOTD |
Offline The Solutor
« Reply #19 on: Wed, 31 August 2011, 15:25:06 »
Quote from: elo820;408250
Does this work on the BW? http://www.youtube.com/watch?v=bLBXxzmuA_Q
BWs are plate mounted, but even if they were pcb mounted like the cherry boards, you had still to desolder the LEDs, which is the hard part of the process due to the tiny holes.
Offline noodles256
  • le legendary
« Reply #20 on: Wed, 31 August 2011, 15:30:52 »
tiny holes
hehe
AF | Ducky YOTD |
Offline nolliepoper
« Reply #21 on: Wed, 31 August 2011, 15:35:52 »
I won't be buying the new BW but I think it's good for Razer to expose different mechanical switches to the public, especially gamers.
Filco MJ2 TKL (Brown)
¯\\_(ツ)_/¯
Offline noodles256
  • le legendary
« Reply #22 on: Wed, 31 August 2011, 15:39:53 »
Quote from: nolliepoper;408271
ok, i won't be buying it either cuz you are not
AF | Ducky YOTD |
Offline keyboardlover
« Reply #23 on: Wed, 31 August 2011, 15:47:22 »
Carl Matsu was right tho.
Offline dreamingftw
« Reply #24 on: Wed, 31 August 2011, 15:54:53 »
I tried to remove the switches from the BW myself but with all the soldering work you will need to do removing the switches and the leds, it's not worth it. I would save $60 and buy the regular black widow ninja when it goes on sale like the cherry blue version IMO.
Offline elo820
« Reply #25 on: Wed, 31 August 2011, 17:07:22 »
Quote from: dreamingftw;408285
Thanks for that. Thanks everyone for helping me out
Offline nolliepoper
« Reply #26 on: Wed, 31 August 2011, 18:22:43 »
Quote from: noodles256;408278
Are you angry at me? I was just trying to provide some insight in my post.
¯\\_(ツ)_/¯
