Author Topic: Where else can esc keys go?  (Read 1282 times)
Offline Son of Gnome
« on: Wed, 31 August 2011, 11:58:09 »
Ok so i have almost filled up the f row on my filco, but I still want to keep getting esc keys. Is there any where esle on the keyboard where they will it?
woody
  •  Guest
« Reply #1 on: Wed, 31 August 2011, 12:05:04 »
Row 4, IIRC.
EDIT: Whatever the number of the row, ESC key fits on the upper row and the one below it.
« Last Edit: Wed, 31 August 2011, 12:09:51 by woody »
Offline Arcanius
  • Buckling Spring Lover
« Reply #2 on: Wed, 31 August 2011, 12:18:37 »
As woody said, Esc, F1-F12, PrintScreen/SysRq, Scroll Lock, Pause/Break, Tilde-+/=, Insert-PgUp, Numlock-Numdivide (Or whatever the top row of a numpad is, if you have one)
« Reply #3 on: Wed, 31 August 2011, 13:08:45 »
The keys on the F-row and the number row have the same profile.
The classic position for the key is to the left of the 1 key. For instance, that is the position on the IBM Model F XT. IBM Model F AT has it on the numeric key pad, next to . (and there are even Model F - clones that have it in both positions...).
woody
  •  Guest
« Reply #4 on: Thu, 01 September 2011, 02:43:50 »
Quote from: Findecanor;408171
The classic position is in the upper left corner, so it's good on the XT and good on the PC101/104. Makes hitting ESC without thinking a breeze.
Now, this below is fscked up:
