Author Topic: Razer Blackwidow Keycaps  (Read 8491 times)
Offline caliber206
« on: Wed, 31 August 2011, 19:44:23 »
Hi,
I have a razer blackwidow and was wondering if keycaps exist for this keyboard. I want to switch it up and have the keys be purple/gold, which are the colors of my school.
If they do not, i was planning on buying some spray paint and doing it that way. Are they fine after being painted? I use my keyboard a lot (starcraft 2 gamer)
Thx,
Caliber
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #1 on: Wed, 31 August 2011, 20:00:24 »
I think it's compatible with cherry keycaps, but I'm not sure. The space/alt/all that might not work out though.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline CookieCutter
« Reply #2 on: Sat, 03 September 2011, 00:35:41 »
I bought a set of imsto's 104 PBT keycaps for my blackwidow. I'll let you know how they fit when they arrive.
Offline Kuroneko
« Reply #3 on: Tue, 06 September 2011, 21:08:49 »
Well I bought some caps from wasdkeyboards and they fit. They'are taller than the regular keys but they fit on just fine. Wouldn't be so sure about the other caps (alt shift ect ect)
Offline noodles256
  • le legendary
« Reply #4 on: Tue, 06 September 2011, 21:20:33 »
Quote from: Kuroneko;411783
dotapub?
AF | Ducky YOTD |
Offline Kuroneko
« Reply #5 on: Wed, 07 September 2011, 08:51:38 »
Quote from: noodles256;411785
dotapub?
