Author Topic: Guys, what causes mouse cursor speed on hardware level?  (Read 3143 times)
Offline NewbieOneKenobi
« on: Thu, 01 September 2011, 09:24:35 »
Is it just dpi or does fps (or whatever the sensor is using) have something to say in the matter? Will an old 400 dpi M$ mouse run slower than an 800 dpi Logitech? (Assuming no drivers, no change in sensitivity sliders, no nothing.)
One reason I'm asking is the opportunity to get M$ Wheelmouse 1.1 for cheap near me (they're having a sale) but it says 400 dpi...
And I mean speed rather than sensitivity (and not acceleration either).
woody
  •  Guest
« Reply #1 on: Thu, 01 September 2011, 10:53:42 »
DPI is DPI. There is cap at acceleration, but it's unrelated.
Interval at which the mouse sends relative movement varies. I have seen it named "polling rate". Varies probably between 125 Hz ... 1 kHz for USB.
« Reply #2 on: Thu, 01 September 2011, 13:49:20 »
Thanks, guys. Also, am I seeing things or do laser mice tend to move the cursor faster than optical ones at the same dpi?
