Author Topic: Topre key stopper  (Read 2711 times)
Offline reaper
Topre key stopper
« on: Thu, 01 September 2011, 13:40:20 »
Sorry for a noob question but how do you install one of these?  Many thanks in advance. =P
Din Eli
Offline tsangan
  • 1000/600
Topre key stopper
« Reply #1 on: Thu, 01 September 2011, 13:41:33 »
What _is_ a key stopper :twitch:
On a side note that red/black combo looks amazing ;D
Keyboardless
Offline itlnstln
Topre key stopper
« Reply #2 on: Thu, 01 September 2011, 13:43:43 »
They stop a key from being pressed (if it's the stopper I'm thinking of; I can't see the pic).  Gamers like to use them on the Win key so accidently pressing it doesn't kick them out of their game.  I've never used one, but I would imagine you just pop the cap and place it over the switch.
Offline reaper
Topre key stopper
« Reply #3 on: Thu, 01 September 2011, 13:45:39 »
Quote from: tsangan;408882
Heh, thanks and I posted a better pic in the pic section (link).
Quote from: itlnstln;408885
Thanks itlnstln.  I tried that but it didn't work. =(
I placed the key stopper on the switch itself unless it has to snap into place or something.
Edit: where's number keyboard expert when you need one. =P
« Last Edit: Thu, 01 September 2011, 14:18:48 by reaper »
Din Eli
Offline RiGS
Topre key stopper
« Reply #4 on: Thu, 01 September 2011, 15:31:40 »
Remove the key next to it then I'm sure you will figure this out.
Offline reaper
Topre key stopper
« Reply #5 on: Thu, 01 September 2011, 17:52:23 »
^ Ok, I'll try that.  Thanks!
Din Eli
Offline thrasymedes
Topre key stopper
« Reply #6 on: Thu, 01 September 2011, 19:35:32 »
Topre Realforce 103 U-UW | IBM 1390131 Model M (1986) | Noppoo Choc Mini (Red)
CST L-TracX | Microsoft Wheel Mouse Optical 1.1a
Offline RiGS
Topre key stopper
« Reply #7 on: Thu, 01 September 2011, 19:39:37 »
Just as I thought.
Offline Disposable Hero
Topre key stopper
« Reply #8 on: Mon, 06 February 2012, 14:58:53 »
where can you get these?...I would like to put one under my Caps Lock....
