Author Topic: KBC Poker Backlighting Mod...is it possible?  (Read 4196 times)
Offline turbocharged
« on: Mon, 05 September 2011, 12:22:10 »
Has anyone proven yet whether or not a full backlight mod is possible on the KBC Poker? I know it has all the holes in the PCB for the LED's but does this actually work (i.e. does it have the built in resistors to handle the leds and what spec LED's will work)?
I should be getting mine in after the GB finishes this month and would consider doing the mod if it is actually possible (as long as I can use any color other than blue...white preferably).
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Mon, 05 September 2011, 12:52:12 »
You mean like this???
[ Attachment Invalid Or Does Not Exist ] 25906[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 25907[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 25908[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 25910[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 25911[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 25912[/ATTACH]
This is the "PURE".  The Taiwanese version of the Poker.  Stay tuned for a GH group buy in a month or two.  ;)
Offline sordna
« Reply #2 on: Mon, 05 September 2011, 13:06:50 »
Quote from: iMav;410953
YES! YES! YES! Do we have any leverage over layout/programmability?
Offline heedpantsnow
  • Old enough to know better
« Reply #3 on: Mon, 05 September 2011, 15:55:10 »
I thought the Pure was commissioned by KBTalking, and the Poker by KBC. They have different layouts as well.
I'm back.
Offline sordna
« Reply #4 on: Mon, 05 September 2011, 16:28:45 »
That's right. I'm just wondering if KBTalking allows any customization for a large order.
Offline peda
« Reply #5 on: Mon, 05 September 2011, 17:10:19 »
Already looking forward to the groupbuy. I hope it will be an international one?!
Sent from my GT-I9000 using Tapatalk
Offline keyboardlover
« Reply #6 on: Mon, 05 September 2011, 17:52:07 »
Sixty modded his poker with leds. Worked fine.
Offline sordna
« Reply #7 on: Mon, 05 September 2011, 18:03:54 »
Quote from: peda;411048
Since you're in Austria, sixty at Deskthority said they will run the European distribution once it's released:
http://deskthority.net/viewtopic.php?f=2&t=1126
« Reply #8 on: Mon, 05 September 2011, 19:46:07 »
Quote from: keyboardlover;411070
Do you have a link to this...very interested.
[SIGPIC][/SIGPIC]
« Reply #9 on: Tue, 06 September 2011, 17:31:59 »
Found it...
http://deskthority.net/viewtopic.php?f=8&t=129
Still wish I knew the specs on what LED's I could put in there. Blue take a lot more power than something like red...would hate to overpower a bunch of LED's.
« Last Edit: Tue, 06 September 2011, 17:35:33 by turbocharged »
[SIGPIC][/SIGPIC]
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Tue, 06 September 2011, 18:39:28 »
I've also been considering modding one of mine, though probably only partially. At the very least replace the existing blue with white or orange. As far as I can tell, 3mm led that would be used for computer case power/hdd indicator should work.
