Author Topic: Diatec now pushing out Filco CAMO keyboards !!  (Read 3733 times)
Offline nikonf5
« on: Wed, 07 September 2011, 19:36:06 »
Funnily enough, I saw this while I was showing the gf what the metallic blue looks like as she will be picking it up later this month from her cousin in Miami and bringing it back to Canada saving me taxes on this end.
First thing I thought of was what color to change the keys to match.
If the blurb is to be believed, every pattern is different and you can see it in the closeup pictures of the logo on all three links.
To cater more to gamers who are the target market, they also have media keys to control volume, etc.
Awesome and they are available in TKL as well!
Sorry, cant seem to post links but if you go to the Diatec main page, you can see it under the product listing section.
Offline fluxrez
« Reply #1 on: Thu, 08 September 2011, 14:21:13 »
For hiding your keyboard in the jungle.
Offline Culinia
« Reply #2 on: Thu, 08 September 2011, 19:34:59 »
You mean this:
LMAO
Can see me playing Battlefield 3 in this...just for the lulz.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #3 on: Thu, 08 September 2011, 19:41:51 »
I like the tilt stand with rubbers.   Safety first, especially in the jungle!
Filco w/ Imsto thick PBT
Offline cirE
« Reply #4 on: Thu, 08 September 2011, 22:03:17 »
Quote from: alaricljs;413064
As do all Filco boards! It's a great feature that I can't believe some manufactures neglect.
FKBN87MC/EB w/ FKBPRM/B
Offline strerror
« Reply #5 on: Thu, 08 September 2011, 23:10:50 »
it also seems to have a number of additional features of the stock standard or is it simply the case that the new marketing was a bit more thorough? eg:
http://www.auspcmarket.com.au/info/KE-FKBN87M-EB2/1838/
compared to:
http://www.auspcmarket.com.au/info/KE-FKBN87M-EMU2/1838/
Offline fluxrez
« Reply #6 on: Fri, 09 September 2011, 17:14:20 »
Quote from: cirE;413117
Though ergo guy at my work said keyboard stands shouldn't be used at all.  They encourage bad wrist positions.
Offline N8N
« Reply #7 on: Fri, 09 September 2011, 17:20:54 »
I somewhat believe that.  I used to use them all the time; then I really made the effort to start touch typing correctly, with good form etc...  Once I did that, I found that I then preferred my keyboard without a stand.  I still use a wrist rest, but don't actually rest my wrist on it most of the time...  usually I use it when I am NOT typing so that I don't scratch up the bracelet of my watch :)  When typing, I find myself holding my hands in a position that is very similar to that if I were playing a piano.
Offline RiGS
« Reply #8 on: Fri, 09 September 2011, 17:22:47 »
I think it would look great with dolch keycaps.
Offline Oqsy
« Reply #9 on: Fri, 09 September 2011, 17:40:06 »
Pushing out?  I'd throw it out. Camo is pretty meh.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline Lanx
« Reply #10 on: Fri, 09 September 2011, 17:46:03 »
Quote from: N8N;413539
your basic 104/87 keyboard is already bad ergonomic wise, so i guess there really is no difference by putting in "regular" footstands that imo are bad
Offline alaricljs
« Reply #11 on: Fri, 09 September 2011, 18:03:51 »
The only water transfer method I know of is used with decals.  You have a special paper with coatings on it and you print your design onto the coated paper.  Stick that in water and the layer immediately next to the paper dissolves and releases the upper layers and your design.  Slide this onto a wet object, press it on and dry it out... the remaining bottom most layer is some sort of glue.
