Author Topic: Slimblade repair?  (Read 7967 times)
Offline smw
Slimblade repair?
« on: Thu, 08 September 2011, 09:16:19 »
Long-time trackball user here...started out with the Microspeed PC-Trac (before they went out of business and the line was purchased by CST); have tried the old Microsoft trackball, a bunch of Logitechs and some other generic trackballs that were never very good. I had beenusing the latest version of the Kensington Expert Mouse for 4+ years, but then one of the ball bearings fell out and Kensington replaced it with a Slimblade (which I love) since they couldn't send me replacement ball bearings or even tell me what size to use (I used a caliper to measure the existing balls and found out they were 2mm; ceramic bearings purchased on eBay worked well as replacements, although they're expensive for what they are). No idea why they didn't send me a new Expert Mouse instead (if I'd complained, they probably would have, and allowed me to keep the Slimblade too).
At any rate, the first Slimblade's buttons were hard to press, as if they were scraping on something. I called Kensington back and they sent me a new one (their replacement policy is very good), so now I have the poorly-working Slimblade in addition to the new one (plus, of course, the now-working Expert Mouse, which serves auxiliary duty for whenever I need to boot up my old Mac G5). I'm wondering if there's any way to disassemble this thing to see if I can fix it and get another trackball working (three for the price of one, more or less!); it seems that if I can get inside and maybe file down whatever's scraping, I can get it working good as new. However, there's no obvious way of opening the thing; I didn't want to start peeling off the feet (are there screws underneath?) if there's no good way of taking it apart.
Anyone?
Whole bunch of 101 key model Ms from the 80s and 90s, plus one Unicomp
Offline smw
Slimblade repair?
« Reply #1 on: Thu, 08 September 2011, 09:48:54 »
Quote from: ripster;412619
Probably the feet.
Bingo!
Actually, not quite - there were actually three screws in the middle covered by a rubber ring, in addition to the four under the feet, but I figured it out easily enough once I got started. And it seems that the problem was that it had been assembled slightly off-center; reassembling properly seems to have fixed it (although I lost the adhesive for two of the feet, but some contact cement should do the trick).
Offline JustCallMeCrash
  • ErgoDox Lover
Slimblade repair?
« Reply #2 on: Thu, 08 September 2011, 13:08:13 »
Hey SMW, I have a solution for the feet.  I've been a big Logitch Trackman Wheel user for ages.  I've had this wireless one for so long that the feet actually melted off... my solution?  Cut a mouse-pad to fit the footprint and glue it on.  I did have to cut a hole out for the battery door, but if you have all hard-wired pointers, it shouldn't be a problem.  The best part is that it now sits up a bit higher (fits my hand better) and doesn't scoot around nearly as much as it used to do.  I could upload a picture, if you want to see it.
ErgoDoxen 6 total: Cherry MX Browns, Cherry MX Clears, NovelKeys Box Royal, 80g Gateron Yellows, NovelKeys Pale Blues, NovelKeys Box Navy.
Preonic 2 total: OG Gateron Yellows (GMK silencer clips), TBD (unassembled v2).
XD-75 (mixed Gateron Yellows, MX Blacks, MX Clears on layer toggles).
Das S Professional (was MX Blues, now Ghetto Reds).
G80-11900.
ML-4400 (2x) Cherry MY boards.
Offline smw
Slimblade repair?
« Reply #3 on: Thu, 08 September 2011, 13:36:13 »
Nah, shouldn't be a problem, I still have the feet, just need to glue them back on.
Thanks, though.
