Author Topic: Someone gave me a Best Buy gift card  (Read 5212 times)
Offline jpc
« on: Thu, 08 September 2011, 21:16:58 »
It's for $100. As they say:
"I've seen better buys, actually."
My monitor died, so I'm in the market for some new kit. Best Buy seems to carry monitors up to 1920x1080. My old monitor was 1920x1200 and I liked the high vertical resolution.
Hey, some CRTs will do 1600x1200. That'll show two tall panes of text. That's what I need. Dear Best Buy, why shouldn't I find a CRT on craigslist and be done?
I opened the dead monitor to see if a connector needed a reseat. Whoa! Flimsy construction! It would be nice to replace it with enterprise grade kit that'll last a decade. Uh does Best Buy carry that?
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Thu, 08 September 2011, 21:21:16 »
Extremely unlikely. You can put that towards an LG IPS lcd though which will be the best display they have to offer.
Offline jpc
« Reply #2 on: Thu, 08 September 2011, 21:32:43 »
Heh I meant it as a rhetorical question, you know what that means?
(pause)
It means you're not supposed to answer it!
(ba-dum chhhhh)
Seriously, yes I was reading about IPS panels. I work with text, so is IPS overkill?
I wish my old monitor hadn't broken. It was fine when it worked -- a Samsung 2433BW. Oh! Names just got NAMED on the flimsy construction!
Offline cirE
« Reply #3 on: Thu, 08 September 2011, 21:52:13 »
Quote from: jpc;413100
be....cause staring at text on a CRT will murder your eyes? I can't go back to CRT.
FKBN87MC/EB w/ FKBPRM/B
Offline jpc
« Reply #4 on: Thu, 08 September 2011, 22:11:29 »
That's a good point. I'm (forced) back to CRT for now. No fun. It helps to have a nice DAC -- I have an old matrox card that I always thought had the most wonderful signal quality -- but still, you're right.
Offline Hydroid
    • http://justin.tv/hydr0id
« Reply #5 on: Fri, 09 September 2011, 02:27:11 »
Why not get a monitor that you can just put in portrait instead of landscape then you can have nice vertical height for text.
Intel Core i7 870 @ 2.93GHz | Corsair H50 | 16GB G.Skill DDR3 | Asus P7P55D-E Pro | Galaxy nVidia GeForce GTX 460 SLI
OCZ 60GB SSD | 2x 1TB Seagate Barracuda RAID-0 | Samsung Blu-Ray Burner | Corsair HX-850W | 2x BenQ G2420HD 24"
Leopold FC200R Tenkeyless Blue | Ducky DK9008(B) Blue | Qsenn DT-35 Black PS/2 Rubber Dome |2x Razer Lycosa USB | Microsoft 500 PS/2
Help me support and grow e-sports below!!!
What Happens in Starcraft -- Vlogs -- Twitter
woody
  •  Guest
« Reply #6 on: Fri, 09 September 2011, 03:21:24 »
Quote from: jpc;413106
Not at all, it's investment in the eye department. Forget TNs, get at least PVA/MVA, or best yet IPS, since they're not that expensive anymore.
Seirously, screw CRT and get IPS. And go DVI-D (or HDMI), then video DACs don't matter.
NEC if you want classy stuff, perhaps EIZO too. Dell if you want to save cash.
It's ten years since I got rid of CRTs and so glad of it.
Offline EverythingIBM
« Reply #7 on: Fri, 09 September 2011, 21:45:12 »
Quote from: cirE;413111
It HUGELY depends on the person. The only thing that can screw with people would be the refresh rate (but otherwise it beats an LCD backlight any day; but the LED backlights are very nice, I love them). 60Hz looks the most sharp. Higher refresh rates start to look too "soft" and slightly smoothed over.
Quote from: jpc;413124
Matrox cards were typically manufactured in Canada and do have high quality, although I have some oddball one made in china that has inserts for SO-DIMMs.
Offline jpc
« Reply #8 on: Tue, 13 September 2011, 21:39:24 »
So I sold the gift card and bought an HP ZR24W. That's a 1920x1200 IPS panel with an sRGB color space (normal gamut, no colorimeter required to calibrate.)
Someone on my local CL was giving away a Sony Trinitron 24" 1920x1200 CRT weighing 92 lbs. Sadly it was gone when I called. Now that woulda looked old skool with a Wang 724 in front of it.
In other news, my old monitor is under warranty?? lolwut?? Haha it's 33 months into a 36 month warranty. So it's on its way back to Samsung. What are the chances they send back a good monitor of the same model?
Offline Arc'xer
« Reply #9 on: Tue, 13 September 2011, 22:35:37 »
Quote from: jpc;415811
Someone was GIVING AWAY?!?! an GDM-FW900? Crazy, just crazy(In good condition it can be anywhere between 250-800 or more). Either it must be in bad condition(especially considering their age) or they probably thought it was damaged or it had a reparable green cast which could be repaired with image restore. Albeit if you know what your doing despite the lower refresh rate you could push the 900 to 2560x1600, above it's recommended maximum of 2304x1440@85hz, though I've seen some mention 90hz with BNC and a few tweaks(which is nice for judder free playback of 30FPS internet video using 90Hz as a equal divisor).
As for the warranty, quite possible you might get a lower grade panel I'm sure after all that time they sold all the A and B panels, they are probably left with C and D stock unless they continued to manufacture or they withhold some volume of the A and B grade; panels for these kinds of things. Though speaking of good panel of the same quality, I do remember a few years ago Samsung was sued due to the way they would sell their monitors and the panel grades or something to that nature and after that lawsuit they began to offer better panel grades even in their lower end models. So you never know you might get lucky and get a good quality grade. Though every once in a while you get people making threads on "panel lotteries" though at this stage with a monitor that old it might not be possible to find a high grade.
« Reply #10 on: Tue, 13 September 2011, 23:28:28 »
LG FW900@85Hz or
viewsonic 1024*768@117Hz
anything under 72Hz is pretty much unviewable to me, though.
arc"xer is right, though it "could" have been an HP 2532a (same as the sony, though beige)
There is a company nearby with about a dozen of these. I want them all. I took apart a broken one once (from the e-waste pile at my univ.), and they're amazing. Easily the best build quality I've yet seen in any display device. Widescreet CRT, bytheway.
I used to have 7 studio (with BNC) trinitrons though now I use an old dell 17" that can somehow go past 1600*1200. It has the best brightness.
woody
  •  Guest
« Reply #11 on: Wed, 14 September 2011, 02:41:34 »
Hope you like it. In an unrelated event I just got U2711 (e-IPS) because it's dirt cheap.
Offline jpc
« Reply #12 on: Wed, 14 September 2011, 08:33:28 »
Quote from: Arc'xer;415842
Not for very long they weren't. The ad said it was in good functional and cosmetic condition.
That's what I get for not checking the CL free section every 15 minutes.
Offline Canada
« Reply #13 on: Thu, 15 September 2011, 00:40:41 »
Quote from: EverythingIBM;413709
I absolutely cannot stand 60hz CRT monitors for more than 15 minutes.  The flickering is bothersome.
75hz and faster are okay, though.
