Author Topic: What keyboard have PCB plates?  (Read 3937 times)
Offline nhwhaup
« on: Fri, 09 September 2011, 16:15:41 »
Not that I need anymore keyboards cause truly I don't, but other than the KBC Pokers, what keyboards have the PCB Plates?
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline redpill
« Reply #1 on: Fri, 09 September 2011, 16:32:45 »
Are you asking which keyboards have the switches mounted directly to the printed circuit board (PCB) and don't have a metal plate?
If so, there aren't many options, but Cherry Corp is known for doing that themselves.
It's unfortunate actually, because I think a lot of keyboard enthusiasts would like a quality tenkeyless keyboard with PCB-mounted Cherry switches for the ease of customization.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline nhwhaup
« Reply #2 on: Fri, 09 September 2011, 16:35:52 »
Quote from: redpill;413507
This is exactly what I mean. After typing on the Poker, I actually like the feel better than other keyboards that have the metal plate.
Offline Lanx
« Reply #3 on: Fri, 09 September 2011, 17:01:28 »
cherry made keyboards (at least the 8200 i've taken apart) feel really, really , really cheap. And yea i think finding a keyboard w/o a plate is gonna be difficult, you could... buy a keyboard, unsolder all the switches, take off the plate, then resolder w/o the plate. That'll prolly take you a good 4hours, i did the exact thing, except i put back the plate tho.
Offline N8N
« Reply #4 on: Fri, 09 September 2011, 17:04:00 »
I think that if you were to do that you would want to also change the bottoms of the switches to the ones with the location pins, and drill the holes for them in the PCB.  I don't think that relying on the solder joints to retain the switches is a good idea.
That, and while it does make the keyboard much harder to customize, I love the solid feel of plate mounted switches, compared to a Cherry board, I don't think I could give that up for a "good" board.
Offline Lanx
« Reply #5 on: Fri, 09 September 2011, 17:08:58 »
naw a good solder joint will hold up anything.
« Reply #6 on: Fri, 09 September 2011, 18:16:22 »
The soldering might hold, but the pad on the PCB might not.
Offline Mr. Perfect
« Reply #7 on: Fri, 09 September 2011, 20:54:51 »
Somebody really needs to try that...
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline pitashen
« Reply #8 on: Sat, 10 September 2011, 00:07:32 »
Quote from: Mr. Perfect;413687
I doubt it is possible as the metal plate actually serves as a support structure, you'll also have to find a way to fix the PCB onto the enclosure.
Offline porgo
« Reply #9 on: Sat, 10 September 2011, 02:58:43 »
Das Keyboard mk2 fits the bill.
There are no ESC keys in prison (poor vim users)
Offline redpill
« Reply #10 on: Sat, 10 September 2011, 12:29:24 »
Quote from: porgo;413814
I thought Das Keyboards were plate mounted?
If a compact layout is acceptable, I think the old Deck 82s were PCB mounted but I'm not sure they make them anymore.  They still list the Ice as being available on their site for $119.  It's backlit which may be good/bad depending on your preference, and they have a unique legend font which you may like/not like.
« Last Edit: Sat, 10 September 2011, 12:34:43 by redpill »
Offline keyboardlover
« Reply #11 on: Sat, 10 September 2011, 14:44:58 »
Is that the model with rollover issues?
Offline darkblader
« Reply #12 on: Sat, 10 September 2011, 15:02:15 »
Déck 82 / Cherry G80 are pcb mounted.
i never thought that the metal plate would do so much extra noice.
CPU : Intel Core i7 920 @ SNK-P0035AP4 | RAM : takeMS 12 Gb DDR3-1333 | GPU : AMD FirePro V4800 1Gb | MOBO : DFI LANparty JR X58-T3H6 | SSD1 : Crucial C300 64 Gb | SSD2 : Intel 320 120 Gb | HDD1 : Hitachi Deskstar 7K1000.C 1Tb | PSU : Scythe Stronger 500W[/COLOR]
Filco Majestouch 2 | Topre Realforce 103 U-UW | Deck 82 Ice | KBC Poker | Cherry G81-7000 | Sun Type 7 | Apple Keyboard (MB110D/B)
[/SIZE]
Offline Minskleip
« Reply #13 on: Sat, 10 September 2011, 15:38:13 »
Quote from: keyboardlover;414069
It's a rebranded Cherry Something, so it should be perfect. I know; I wrote my dissertation on one. <- Minskleip is scientist.
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
