Author Topic: DIY membrane  (Read 2331 times)
Offline wcass
DIY membrane
« on: Sat, 10 September 2011, 21:39:05 »
So I find myself obsessively trying to refine and improve this keyboard. I like buckling springs, so it is based on a Model M. It is tenkeyless and the same width as a SSK, but with 8 more keys. Now I’m thinking of making a custom membrane and controller. The controller would be an Aikon or something based on the Teensy++. My idea for the membrane is to print the shape and traces on an 11 x 17 transparency, then cut it and re-draw the traces with a conductive ink pen. Has anyone ever heard of anyone trying this?
Thanks
Offline litster
  • rare caps?! THAT'S A SMILIN
DIY membrane
« Reply #1 on: Sat, 10 September 2011, 21:58:34 »
This looks cool.  Would it be possible to make a regular M into a mini?
Offline wcass
DIY membrane
« Reply #2 on: Sat, 10 September 2011, 22:09:20 »
Quote from: litster;414228
Sure. it is actually easier than what i did. I got the idea from Daniel Beaver who did it with a standard 101 key M. The end product is about a half inch wider and deeper than a "factory" SSK.
