Author Topic: My keyboard does not have 104 keys... (Linux X11 conf)  (Read 4240 times)
Offline mcc
« on: Sun, 11 September 2011, 11:07:49 »
Hi,
I am running a recent Gentoo Linux with X-Windows and an IBM model M
via a Belkin PS2=>USB converter (active).
The IBM model M is a PC101 US-layut one (1390131).
I am using the evdev Interface, not hald.
The keyboard runs without problems...as it /seems/.
But running xkeycaps shows me, that some keys -- at least
in the mind of xkeycaps where recognized wrongly.
Whe using setxkbmap -v 10 -query shows me, that the system thinks
the model m has 104 keys.
I tried to set it to pc(pc101) via setxkbmap with no success.
I tried it via xorg.conf and xorg.conf.d...no success.
Is there any way to tell the system, that my IBM model m
only has 101 keys?
Thank yoiu very much in advance for any help!
Best regards,
mcc
Offline D-EJ915
« Reply #1 on: Sun, 11 September 2011, 12:07:03 »
It doesn't make any difference does it?
Offline mcc
« Reply #2 on: Sun, 11 September 2011, 12:20:06 »
Hi,
thank you very much for your help D-EJ915 and Ripster!
I will try, what you have suggested.
Best regards,
mcc
Offline mcc
« Reply #3 on: Mon, 12 September 2011, 12:59:21 »
Hi,
thanks for zour more helpful answers ! :)
But...this "I have 104 keys to offer"-behaviour is in front
of the X-server...and I had told the X-server via configs,
that it should interpret the keyboard as pc101...but it
simply ignores that.
BUT if I tell the X-server, that it would be QWERTZ instead of QWERTY
it seems no problem for it to accept this.
This seems to me a inconsistency in logic...as far as it is based on
logic at all...
At least xkeycaps get confused and therefore xmodmap will be unuseable
too as I fear (knowing that xmodmap is deprecated though)...
Or am I totally wrong here ?
Best regards and have a nice weekend!
mcc
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Mon, 12 September 2011, 13:12:41 »
Shouldn't matter, the difference between 101 and 104 keys is the addition of 3 specific key codes and no changes to the original 101 codes.  In what way does xkeycaps get confused?  When I run xkeycaps it tells me no keyboard type was specified and that a PC105 will be assumed.  As for xmodmap being deprecated... don't hold your breath.  It's been that way for many years.
Filco w/ Imsto thick PBT
Offline JBert
« Reply #5 on: Mon, 12 September 2011, 15:21:22 »
Ehr, when I run xkeycaps without arguments, it just asks me what the layout is. I only use it to test keyboards, and once you select the right layout, it works alright.
The storage list:
Currently ignored by: nobody?
[/SIZE]
