Author Topic: Cherry MX Greens  (Read 7275 times)
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
Cherry MX Greens
« on: Sun, 11 September 2011, 20:46:15 »
From what I've seen, greens are used primarily for spacebars. Is it crazy talk to want an entire board of greens? Mainly because I like the color green.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline elbowglue
Cherry MX Greens
« Reply #1 on: Sun, 11 September 2011, 21:45:57 »
The feel of a cherry green is almost = a cherry blue stem with a cherry black spring.  So if you took a G80-3000 with blue switches, changed all the springs to black springs from another source, it would feel like a full cherry green keyboard.
Of course if you just want green colored stems you could try to paint the stems. :)
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline Quarzac
  • A very busy dude!
Cherry MX Greens
« Reply #2 on: Mon, 12 September 2011, 00:35:24 »
You sir, understand. I think I will probably just try to paint the stems if WASD ever stocks a darker green. Greens are apparently kind of hard to come by. Although I bet they're pretty cool.
Offline What is X?
Cherry MX Greens
« Reply #3 on: Mon, 12 September 2011, 05:14:07 »
But... keycaps go over the switches so you can't see the colour anyway?
Offline guilleguillaume
Cherry MX Greens
« Reply #4 on: Mon, 12 September 2011, 06:03:55 »
Ascaii modded his keyboard to greens:
Offline Bilbin
Cherry MX Greens
« Reply #5 on: Mon, 12 September 2011, 08:47:15 »
I've been wanting a full board of greens for a while now. Some guy was selling individual ones on deskthority a while back, probably still is.
Just couldn't be bothered learning to solder just to replace 87 key switches, most likely damaging the keyboard permanently.
I doubt ghetto-greens feel like greens, same way that ghetto-reds probably don't feel the exact same as reds.
Filco Majestouch Tenkeyless Blues - Razer Abyssus - PureTrak Talent
Offline N8N
Cherry MX Greens
« Reply #6 on: Mon, 12 September 2011, 08:50:22 »
If it makes you feel any better I dove in the deep end and put clears in my Filco (and mine has 104 keys!) a while back and I didn't break anything! (have actually been using it at work, and it hasn't hiccupped on me yet)  So it can be done...  Now I did have some previous soldering experience from restoring old cars, but this was the first serious work I'd done involving PCBs.
Also, rather than buying a whole set of greens, you could just buy a POS keyboard with clears or blacks and harvest the springs for "ghetto greens" - would likely be much less expensive, although slightly more labor intensive (you'd have to put the heavier springs in your existing Filco switch bodies...
Offline SmallFry
Cherry MX Greens
« Reply #7 on: Mon, 12 September 2011, 09:02:03 »
I've been wanting to do this too... I say we organize a group buy of them. Because if we got over 1000 switches we might be able to talk to cherry directly. Just an idea. Sounds pretty BA, not gonna lie.
Offline peda
Cherry MX Greens
« Reply #8 on: Mon, 12 September 2011, 09:12:28 »
If I recall directly, there are rumors that the new CM mechanical keyboard will have an option to get it with full greens (and clears)
I espacially hope for the clears to happen B-)
Sent from my GT-I9000 using Tapatalk
Offline keyboardlover
Cherry MX Greens
« Reply #9 on: Mon, 12 September 2011, 09:29:14 »
Greens are like a clicky panda clear, but even heavier! Very manly switch.
Offline redpill
Cherry MX Greens
« Reply #10 on: Mon, 12 September 2011, 09:33:12 »
Sounds fun
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded Keycaps |  Ducky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Cherry MX Greens
« Reply #11 on: Mon, 12 September 2011, 09:36:54 »
Quote from: elbowglue;414678
I would agree with this. Good description.
Iirc it might be heavier but im not sure. Might check later tonight.
Offline r4pture
Cherry MX Greens
« Reply #12 on: Mon, 12 September 2011, 09:37:55 »
How would greens compare to buckling spring?  If its how I think it would be, then a full NKRO MX Green keyboard would be my absolutely perfect keyboard.
....if it had dark purple one it somewhere, at least.  :D
[sigpic]http://geekhack.org/signaturepics/sigpic12085_2.gif[/sigpic]
~ Dell AT101W~ ~ ~ ~IBM Model M2~ ~ ~Northgate Omnikey 101 ~
Offline gilgam
Cherry MX Greens
« Reply #13 on: Mon, 12 September 2011, 10:40:27 »
Quote from: Bilbin;414829
They are very near,
i have both on two different keyboards and i used old blue switches spring whith new black stems and full new red switches.
And i can't feel the difference, which doesn't mean there isn't of course :-)
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Cherry MX Greens
« Reply #14 on: Mon, 12 September 2011, 11:20:47 »
Quote from: keyboardlover;414841
This sounds awesome.  I just finished modding two boards to ghetto reds and ergo clears.  I'll have to try ghetto greens next.
Offline sordna
Cherry MX Greens
« Reply #15 on: Mon, 12 September 2011, 13:34:39 »
Quote from: Quarzac;414664
Since you asked, I would have to answer yes, IMO it is crazy.
Quote from: Quarzac;414740
Why do you care about the stem color, which is not even visible unless you take the keycaps off ???
Offline Quarzac
  • A very busy dude!
Cherry MX Greens
« Reply #16 on: Mon, 12 September 2011, 20:16:09 »
Quote from: sordna;414992
Because I will KNOW. I will know that my board is green at heart, even if it's black on the outside.
Offline hashbaz
  • Grand Ancient One
Cherry MX Greens
« Reply #17 on: Mon, 12 September 2011, 20:49:18 »
But if you paint the stems it will all be a sham.  And you know it.
Offline Quarzac
  • A very busy dude!
Cherry MX Greens
« Reply #18 on: Mon, 12 September 2011, 21:14:46 »
Quote from: hashbaz;415258
Damn you. Now I will never have peace. Unless of course I come by 104 greens, or 87 and a TKL board.
Offline Bilbin
Cherry MX Greens
« Reply #19 on: Mon, 12 September 2011, 21:32:56 »
2nd of June email from blainchen on Deskthority.
Price per switch is EUR 0.85.
Shipping is EUR 15.00 to Australia.
It would cost $101 USD without shipping for 87 MX green key switches.
Offline Quarzac
  • A very busy dude!
Cherry MX Greens
« Reply #20 on: Mon, 12 September 2011, 21:36:16 »
Quote from: Bilbin;415277
Well, this is one dream I am abandoning.
Offline Bilbin
Cherry MX Greens
« Reply #21 on: Mon, 12 September 2011, 21:44:52 »
You could always start saving :wof:
...Or hope we get a 1000 switch group buy going.
