Author Topic: Clear keycaps  (Read 4048 times)
Offline Bilbin
  • Trade Count: (0)
Clear keycaps
« on: Wed, 14 September 2011, 00:45:13 »
Was wondering if anyone has completely clear 100% polished inside and out clear keycaps that they are keen on selling.
Something like
http://deskthority.net/download/file.php?id=224
instead of
[ Attachment Invalid Or Does Not Exist ] 26584[/ATTACH]
Filco Majestouch Tenkeyless Blues - Razer Abyssus - PureTrak Talent
Offline simon_C
  • Trade Count: (0)
Clear keycaps
« Reply #1 on: Wed, 14 September 2011, 03:07:04 »
youll probably have to contact Signature plastics. glossy clear is waht youll be looking for.
Offline Bilbin
  • Trade Count: (0)
Clear keycaps
« Reply #2 on: Wed, 14 September 2011, 09:05:19 »
Thanks man. I thought that was the clear they did for the group buy, IIRC people wanted polished/glossy clear but they gave them that instead.
Offline Bilbin
  • Trade Count: (0)
Clear keycaps
« Reply #3 on: Wed, 14 September 2011, 13:31:36 »
This is what she said she could get me.
[ Attachment Invalid Or Does Not Exist ] 26630[/ATTACH]
I asked Melissa what she thinks about using a very fine grit sand paper to remove the texturisation on the top of the keycaps.
Offline Bilbin
  • Trade Count: (0)
Clear keycaps
« Reply #4 on: Wed, 14 September 2011, 14:42:07 »
No dice, apparently sanding it would make it even more blurred. Guess I'm going to have to go for the ones in the picture. :)
Offline simon_C
  • Trade Count: (0)
Clear keycaps
« Reply #5 on: Thu, 15 September 2011, 03:21:39 »
well if you sanded with progressively finer grits up to 2000, you can then polish it with plastics polish. just fyi there is a user here selling 104 key clear sets.
Offline Bilbin
  • Trade Count: (0)
Clear keycaps
« Reply #6 on: Thu, 15 September 2011, 07:27:34 »
Yeah, he PM'd me but I don't think he wants to part with 16 keys, that and SP are quoting me $21.50 delivered to Australia.
I might try sanding the key cap that will go on Pause Break and see what happens.
Offline simon_C
  • Trade Count: (0)
Clear keycaps
« Reply #7 on: Thu, 15 September 2011, 13:17:35 »
get one of those car headlamp lense restore kits. they have several grits of sandpaper and a bottle of plastic polish and are relatively cheap.
Offline jefferysanders
  • Trade Count: (0)
Clear keycaps
« Reply #8 on: Thu, 15 September 2011, 14:12:36 »
Who has the perfect clear 104 sets?  I looked around ABS is the common clear material, but PC be way better (correct?)  So my hunt continues for crystal clear PC keycaps.
Offline Bilbin
  • Trade Count: (0)
Clear keycaps
« Reply #9 on: Fri, 16 September 2011, 01:57:49 »
Quote from: simon_C;416679
Thanks, will need to have a look at my local car stuff shop. How would I go by it exactly? rough - fine sanding then polish, or just fine?
http://geekhack.org/showthread.php?21674-Lots-of-key-caps-for-sale.-104-clear-37-PBT-Customized-keys-and-Aluminum-keys
feng is the guy.
« Last Edit: Fri, 16 September 2011, 02:00:33 by Bilbin »
Offline Bilbin
  • Trade Count: (0)
Clear keycaps
« Reply #10 on: Fri, 16 September 2011, 02:41:29 »
Threadcrapping!
Ha ha! I've caught you in the act!
