Author Topic: Filco doesn't like my USB hub?  (Read 1838 times)
Offline porgo
« on: Tue, 20 September 2011, 07:01:09 »
My Filco with browns starts flashing the leds when I stick it to my close USB hub (active so the power shouldn't be an issue). The OS gets the board only to disconnect it immediately. It then loops until I unplug it. When plugged bypassing the hub, things work as expected.
Is there something I can do to this? Every gadget that accepts the hub is one less cord to run over the room (my PC is a few feet away in the closet).
There are no ESC keys in prison (poor vim users)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Tue, 20 September 2011, 07:40:13 »
Different hub?  I had to switch hubs when I got my Filco, but it turns out the hub I was using was crapping out anyhow.  The hub was very hot when I had it plugged in and a quick file transfer test showed that it wasn't just keyboards that it didn't like.  Data rates were very slow from all the re-transmits going on.  The keyboard symptom was random extra key strokes while typing.
Filco w/ Imsto thick PBT
Offline gmorf33
« Reply #2 on: Tue, 20 September 2011, 08:31:02 »
or plug your keyboard straight into the PC and your other devices into the hub.
Offline porgo
« Reply #3 on: Tue, 20 September 2011, 09:10:13 »
Quote from: alaricljs;419032
Yeah, I'd have tried if I had an extra one. The hub is a cheapo "i-rocks" but it works well with the other USB equipment.
Offline Pylon
« Reply #4 on: Tue, 20 September 2011, 13:45:19 »
Hubs will occasionally lead to weird issues. I had a hub that would always BSOD the computer if I plug a WiFi adapter into it.
