Author Topic: Navigation everything without a mouse!  (Read 6813 times)
Offline siouxscout
« on: Wed, 21 September 2011, 10:41:44 »
Anyone else using software so you can use only the keyboard? Trying Numbad Mouse and its alright nothing gives you the speed or a mouse I guess, but im gonna keep playing with it.
Hate having to take my hands off the keyboard to do work on some things, I miss my loved nix command line apps :(.
« Last Edit: Wed, 21 September 2011, 10:44:06 by siouxscout »
[SIGPIC][/SIGPIC]
Offline Daniel Beaver
« Reply #1 on: Wed, 21 September 2011, 11:36:25 »
Windows is surprisingly usable without a mouse. To assist with mouseless use, I would recommend: Launchy, which is a program and file launcher, and WinSplit Revolution, which grants very fine-tuned control of window placement using the keyboard. For browsers, it helps to use something like vimperator or vimium (though they can get in the way of mouse usage).
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline Mazora
« Reply #2 on: Wed, 21 September 2011, 12:36:18 »
i personnally use keybreeze and plenty of autohotkey scripts
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline enoy21
« Reply #3 on: Wed, 21 September 2011, 12:58:10 »
Lol Those of us that were around in the DOS 6.22 days are a little more accustomed to those needs.  I ran windows 3.1 and Windows 95 without a mouse often.   Back then we didn't have a windows key.... ALT+ was your friend.      I don't think ALT+f4 even still works does it ?  I haven't gotten anyone with that trick in games in a while.
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline Mazora
« Reply #4 on: Wed, 21 September 2011, 13:20:32 »
alt-f4 is definitely a valid hotkey
RF-87UW
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #5 on: Wed, 21 September 2011, 13:41:43 »
Shortcut keys for Windows8: http://www.winsupersite.com/article/windows8/windows-8-tip-windows-key-shortcuts-140626
http://support.microsoft.com/kb/126449
[h=3]Windows system key combinations[/h]
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Back to the top
[h=3]Windows program key combinations[/h]
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Back to the top
[h=3]Mouse click/keyboard modifier combinations for shell objects[/h]
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
Back to the top
[h=3]General keyboard-only commands[/h]
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Back to the top
[h=3]Shell objects and general folder/Windows Explorer shortcuts[/h]
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
[h=4]To copy a file[/h]
Press and hold down the CTRL key while you drag the file to another folder.[h=4]To create a shortcut[/h]
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
Back to the top
[h=3]General folder/shortcut control[/h]
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95  Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus  all parent folders
Back to the top
[h=3]Windows Explorer tree control[/h]
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not  expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded,  otherwise goes to the parent
Back to the top
[h=3]Properties control[/h]
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Back to the top
[h=3]Accessibility shortcuts[/h]
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds:  Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Back to the top
[h=3]Microsoft Natural Keyboard keys[/h]
  • Windows Logo:           Start menu
  • Windows Logo+R:         Run dialog box
  • Windows Logo+M:         Minimize all
  • SHIFT+Windows Logo+M:   Undo minimize all
  • Windows Logo+F1:        Help
  • Windows Logo+E:         Windows Explorer
  • Windows Logo+F:         Find files or folders
  • Windows Logo+D:         Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F:    Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB:       Cycle through taskbar buttons
  • Windows Logo+Break:     System Properties dialog box
  • Application key:   Displays a shortcut menu for the selected item
Back to the top
[h=3]Microsoft Natural Keyboard with IntelliType software installed[/h]
  • Windows Logo+L:         Log off Windows
  • Windows Logo+P:         Starts Print Manager
  • Windows Logo+C:         Opens Control Panel
  • Windows Logo+V:         Starts Clipboard
  • Windows Logo+K:         Opens Keyboard Properties dialog box
  • Windows Logo+I:         Opens Mouse Properties dialog box
  • Windows Logo+A:         Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR:  Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S:        Toggles CAPS LOCK on and off
Back to the top
[h=3]Dialog box keyboard commands[/h]
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item:  Move to the corresponding item
