Author Topic: [Interest Check] KBC 104 ABS Clear Cherry MX Key Caps  (Read 10539 times)
Offline feng
« on: Thu, 22 September 2011, 15:20:12 »
Anyone interested in KBC 104 ABS Clear Cherry MX Key Caps?
The price is $30 plus shipping for each set. I think the shipping costs about $3 via USPS First Class shipping to CONUS.
I'll post a new thread for the group buy if there're more than 10 people interested.
[ Attachment Invalid Or Does Not Exist ] 27072[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27073[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27074[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27075[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27076[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27077[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27078[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27079[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27080[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27081[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27082[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27083[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 27084[/ATTACH]
Offline jpm804
  • KeyCap Assasin
« Reply #1 on: Thu, 22 September 2011, 15:40:27 »
I might be interested....Also for the spacebars will it only fit Filco's and not leopolds or will it fit both.
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline reaper
« Reply #2 on: Thu, 22 September 2011, 17:02:20 »
Looks good. I might be in for a set.
« Last Edit: Sat, 24 September 2011, 10:43:41 by reaper »
Din Eli
Offline feng
« Reply #3 on: Thu, 22 September 2011, 20:40:06 »
Quote from: jpm804;420153
The spacebards only fit Filco's and not Leopolds.
Offline nikonf5
« Reply #4 on: Fri, 23 September 2011, 09:22:23 »
Just curious as to whether this is the same product that qtan has listed at the following link:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/pbt-key-caps/kbc-104-half-clean-key-caps-fo/lid=19160792
I ask because I was looking for transparent key caps [for a non-led kbd] or as close to transparent as possible with plastic and I found qtans link but he specifically calls them half-clears which is his way of saying slightly smoky or translucent.
I have seen "real" clears in a pic elsewhere on this forum on a Cherry Red TKL, cant remember where though and once you have seen that, you can tell the difference clearly as the whole switch under the keycap is visible clearly.
Looking at a backlit pic can be very deceiving and the pic that actually turned me away from the half-clears is the last one in this post where you cant see anything under the keycap except at an angle. [ins, del & up arrow key]
In any case, dont want to turn anyone away from this as half-clears are only a problem for non-backlit keyboards which is what I was going to be using them on but if anyone knows where completely clear keys can be bought, let me know via PM.
Thanks.
Offline feng
« Reply #5 on: Fri, 23 September 2011, 12:35:19 »
Quote from: nikonf5;420379
Thanks.
Yes it's the same. We call it Half-Clear keycaps in China, because it's not completely transparent.
Anyway, I guess the #5 Transparent keycaps I have for sale is the "real" clears that you are talking about. Here's the link:
http://geekhack.org/showthread.php?21674-Lots-of-key-caps-for-sale.-104-clear-37-PBT-Customized-keys-and-Aluminum-keys.
Offline nolliepoper
« Reply #6 on: Sat, 24 September 2011, 12:51:22 »
Edit: Maybe interested.
« Last Edit: Wed, 28 September 2011, 00:15:30 by nolliepoper »
Filco MJ2 TKL (Brown)
¯\\_(ツ)_/¯
Offline r00t_b33r
« Reply #7 on: Sat, 24 September 2011, 14:18:04 »
« Last Edit: Mon, 17 February 2025, 14:41:50 by r00t_b33r »
Offline Tanooki
« Reply #8 on: Sat, 24 September 2011, 18:40:33 »
Another one interested.
Offline xmrxkrazy
« Reply #9 on: Sun, 25 September 2011, 01:03:20 »
In for one!
Offline feng
« Reply #10 on: Tue, 27 September 2011, 16:16:48 »
So far, 5 interested for sure, 2 might be interested.
Offline N8N
« Reply #11 on: Fri, 30 September 2011, 14:42:29 »
I'd be down for a set.  Might tip me over the edge to buy a Rosewill...  or mod something and paint the plate something cool like a 3-layer candy/flake or something.
Offline noodles256
  • le legendary
« Reply #12 on: Fri, 30 September 2011, 15:27:29 »
id get one if it is only $30
AF | Ducky YOTD |
Offline akerasi
« Reply #13 on: Fri, 30 September 2011, 19:32:49 »
In for one, maybe two.
Owns, no particular order:
Ricercar SPOS (Variable Force Mod number 3), 122-key IBM terminal board (future project to learn a Teensy), 1993 IBM Model M, Dell AT101W, 3x Cherry G80-8200LPBUS (2 in pieces, 1 modded to Ghetto Reds), Cherry G80-1190HRMIT(Variable Force Mod), Wang 724 Terminal Keyboard (Pink Alps), Cherry G84-4100, Cherry G81-LUMUS, a pile of random old ALPS Macintosh boards in poor condition.
Wants:
Odd keyswitch boards for cheap (NEC sliders, space invaders, other weird stuff), Cherry Blues for cheap
Offline jefferysanders
« Reply #14 on: Fri, 30 September 2011, 20:48:55 »
I am interested in a (PC) Otaku complete clear 104 set if available.  I would pay up to a 100USD for this if no bubbles.
Offline RColinTaylor
« Reply #15 on: Sat, 01 October 2011, 20:16:15 »
If were talking $30 for a 104 set of semi-clears then yes, consider me interested.
I like my Browns more than my Blues.
Offline feng
« Reply #16 on: Wed, 05 October 2011, 09:32:03 »
Since there's about 10 people interested, I'll open up the group buy in a new thread by today.
