Author Topic: Where can I get some keycaps made?  (Read 5725 times)
Offline NguyenAdam
« on: Tue, 27 September 2011, 00:48:26 »
I see all of these group buys being arranged for custom keycaps. Where are these being made, and can they fulfill small orders for certain individuals for a fair price?
« Reply #1 on: Tue, 27 September 2011, 01:51:18 »
Signature plastics is the usual culprit. They have no minimum quantity, bet they do have a minimum order amount ($100, according to their faq). I donsider this a very fair price, especially for small runs. Many larger plastics houser won't touch you unless you're buying 100,000+ units.
Here's the website:
http://keycapsdirect.com/key-caps.php
FAQ:
http://keycapsdirect.com/faq.php
They are being made in Washington, USA
"Signature Plastics
7837 Custer School Rd
Custer, WA 98240"
Offline itlnstln
« Reply #2 on: Tue, 27 September 2011, 07:06:21 »
Also check out WASDKeyboards.  They do custom caps as well.  SP will give you a little more flexibility in colors, but WASD can do it for cheaper.
Offline NguyenAdam
« Reply #3 on: Tue, 27 September 2011, 14:18:30 »
How much is it usually for one key?
Offline Pylon
« Reply #4 on: Tue, 27 September 2011, 15:51:33 »
If you're doing one key and not a group buy SP is pretty much not an option unless you want to pay $100 for that one key.
Offline NguyenAdam
« Reply #5 on: Tue, 27 September 2011, 15:54:25 »
I wouldn't mind putting a group buy together, but I'm new to this. I'm thinking about a One Piece styled theme.
http://geekhack.org/showthread.php?21674-Lots-of-key-caps-for-sale.-104-clear-37-PBT-Customized-keys-and-Aluminum-keys.
I would really like some keycaps similar to that, but maybe in black.
