Author Topic: non-clicky key on new filco blue  (Read 3927 times)
Offline bitt3n
« on: Fri, 30 September 2011, 13:17:16 »
I've noticed that the j key on my ~2 week old filco blue TKL does not actually click (while the other keys make the normal distinct click of blues). Is there anything to do about this except return it? That would be a pain, since who knows when they'll be in stock again. The key is functional but does not click.
Offline itlnstln
« Reply #1 on: Fri, 30 September 2011, 13:25:30 »
Pull the cap, press down the stem a little, and blow it out with and air duster.  Cherry blues are sensitive to dust and other foreign particulates in the switch.
Offline bitt3n
« Reply #2 on: Fri, 30 September 2011, 13:55:20 »
cool I just ordered some canned air, will give it a try. If it doesn't work, is the switch easy to remove/replace myself, if I order a single blue off ebay?
Offline itlnstln
« Reply #3 on: Fri, 30 September 2011, 13:57:36 »
It'll be easy to replace if you're good at soldering.  If it really is defective, I would send it back; I wouldn't try fixing a new 'board.
That didn't work out so well for a former member here.  In fact, he was blacklisted from Elitekeyboards and several other retailers.
Offline Lanx
« Reply #4 on: Fri, 30 September 2011, 14:04:07 »
desolder and use scroll lock-key most common donor key. ebay rip off blues are like 4.99? lol
Offline itlnstln
« Reply #5 on: Fri, 30 September 2011, 14:06:17 »
I still wouldn't do that for a new 'board.
Offline bitt3n
« Reply #6 on: Fri, 30 September 2011, 14:20:19 »
I've actually got a malfunctioning blackwidow I could cannibalize, but soldering a 2-week old board seems maybe not so smart
Offline Ekaros
« Reply #7 on: Fri, 30 September 2011, 14:21:23 »
If it's under warranty try non-intrusive method like cleaning. And then try to get it replaced. If everything else fails get dirty and forfeit the warranty.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline itlnstln
« Reply #8 on: Fri, 30 September 2011, 14:23:28 »
^ Exactly right.
Offline Ekaros
« Reply #9 on: Fri, 30 September 2011, 14:28:40 »
Quote from: ripster;424181
Technically Wellington1869 opened up all the ALPS on his Zero, replaced the sliders with dampened ALPS from a Apple AEKII donor, added click leaves, and THEN complained when Elitekeyboards wouldn't take it back.  He did not take the refusal well and he labelled us both Elitekeyboard fanbois.  In other words it was a bit like ping this summer.
I consider that intrusive, I wouldn't take it back either. It's like you buy a computer, replace parts with 5 year old used ones and then try to return it... ;D
[SIGPIC][/SIGPIC]
Offline bitt3n
« Reply #10 on: Fri, 30 September 2011, 14:33:36 »
Quote from: Ekaros;424178
my conundrum is I purchased from amazon US so they will just refund my money since it's not in stock, whereupon I have no keyboard. if I RMA it I expect I'll have to send it to the UK (presumably, since it was sold through amazon by keyboard co UK). I guess I'll pray that canned air fixes it.
Offline itlnstln
« Reply #11 on: Fri, 30 September 2011, 14:36:23 »
I would still avoid replacing the switch.  You just spent $150-ish on a new 'board.  If something else were to go wrong that you couldn't fix, you would have no recourse.
Offline Saturn
« Reply #12 on: Fri, 30 September 2011, 18:19:37 »
Quote from: bitt3n;424187
if the order was fulfilled by keyboard co, then you might try contacting them directly about the issue.  they have a website outside of amazon where they conduct their own sales and hopefully would be willing to send you a replacement if they have one in stock.
Offline simon_C
« Reply #13 on: Fri, 30 September 2011, 21:35:46 »
i had one or two keys on my xarmor that did that, i just rapped on the key a few times fairly hard, popped the keycap off, and put it back on and it worked again.
Offline Clickey
« Reply #14 on: Sat, 01 October 2011, 14:35:31 »
In order to desolder a switch you will have to break the warranty seal on the back. So if you go that route, then you gotta go all the way. I dont think Amazon would accept the return after that.
"we are on Geekhack not Lazy****" - The Solutor
Offline bitt3n
« Reply #15 on: Sun, 02 October 2011, 13:00:35 »
Quote from: ripster;424595
Have you tried spamming the key like F5 at 4chan?
(Attachment Link) 27710[/ATTACH]
yep and I popped the cap off and put it back on without success.. I'm waiting for the compressed air to arrive and if that doesn't work, I guess I might return it
