Author Topic: Stuck key on a IBM Model M  (Read 5707 times)
Offline RiGun
« on: Sun, 02 October 2011, 00:56:10 »
Hey guys, I've found a 1992 Spanish Model M in good condition but it has one problem, the [ key is stuck, you can press it and it makes a clicking noise but the [ appears before you hear the click, also sometimes a [ randomly appears after I hit the letter P, I took the keycap and didn't see any difference with other keys, I don't have the tool to open it so before I start looking for one I thought I should ask if anyone know if there is a way to fix this.
Any idea what the problem might be?
Offline Ascaii
« Reply #1 on: Sun, 02 October 2011, 02:13:33 »
You will need to reseat the sping on the hammer, the easiest way is the chopstick-o-death method by sandy55. Search for it on the gh search.
Ripster also posted this pic, which might help you understand what I mean better:
http://geekhack.org/showthread.php?8731-Broken-spring&p=156128&viewfull=1#post156128
Offline RiGun
« Reply #2 on: Sun, 02 October 2011, 03:43:50 »
Thanks a lot for the quick answer, I'll try this as soon as I get home.
