Author Topic: Swapping backspace/capslock?  (Read 7532 times)
Offline GigaFlop
« on: Mon, 03 October 2011, 10:09:56 »
I would have just asked Ripster about this, but apparently he isn't allowed/blocks all PM's.
I'm considering swapping the functionality of backspace and capslock with Autohotkey. Will the LED on my keyboard still light up if I press the button that used to be capslock? That's really the only thing I'm worried about, as I don't like when that light is on. And I don't know yet how Autohotkey will affect my computer overall, or I would just test it myself.
Any help is appreciated, thanks.
Oh god why did my wallet get so thin
fossala
  •  Guest
« Reply #1 on: Mon, 03 October 2011, 10:26:07 »
I use my caps key as a ctrl on Linux and it does not light up with a Unicomp spacesaver.
Offline vun
  • Just one more thing
« Reply #2 on: Mon, 03 October 2011, 10:32:19 »
I recently started using AHK to replace Caps Lock with shift, doesn't light up and AHK hasn't had any negative effects on my computer.
Offline Playtrumpet
« Reply #3 on: Mon, 03 October 2011, 13:35:29 »
You should be able to control the functionality of your LEDs. I've had a bit too much fun (using a different program) programming my LEDs to do weird things when I hold down certain keys, and I do have it set to keep the Caps Lock LED unaffected by a Caps Lock keypress. (For fun though, I made it so it lights up when I press a Shift key (goes along with capital letters)).
Dvorak
Offline GigaFlop
« Reply #4 on: Mon, 03 October 2011, 13:45:38 »
Thanks, all. Here is a gift for your help.
Quote from: Playtrumpet;425592
What program would that be?
Offline Deverica Wolf
  • My name is Hack, Geek Hack.
    • Head-Fi
« Reply #5 on: Mon, 03 October 2011, 13:59:52 »
Quote from: GigaFlop;425475
Go ahead and do it. I did the same thing. As long as you do it right, AutoHotKey won't harm anything and you can always take a Hotkey off.
The Caps LED will never come on.
UNICOMP.Spacesaver BS  |  FILCO Majestouch-2 TKL  |  FILCO Majestouch-2  [-_-]~ TKL  |  FILCO Majestouch-2 TKL
FILCO Majestouch-2 TKL  |  Deck Legend - ToXic  |  CHERRY Touchboard ITA
Offline sam113101
« Reply #6 on: Mon, 03 October 2011, 14:01:34 »
I've remapped capslock and backspace but not using autohotkey, because I wanted my remapping to take effect directly at login.
Hoping to hear from you again, your dearest friend, sam113101.
Offline Playtrumpet
« Reply #7 on: Mon, 03 October 2011, 14:41:49 »
Quote from: GigaFlop;425601
Oh, I'm a Mac user so I didn't bother mentioning, but I use ControllerMate.
Dvorak
Offline GigaFlop
« Reply #8 on: Mon, 03 October 2011, 16:15:36 »
I am so amused right now! Gone are my days of reaching all the way to the corner of my keyboard to delete a mistake!
Even though I keep reaching for what used to be backspace while writing this.. I guess a few days of internet should help.
« Last Edit: Mon, 03 October 2011, 16:28:58 by GigaFlop »
Offline Playtrumpet
« Reply #9 on: Mon, 03 October 2011, 20:37:29 »
I don't know why, but I still haven't begun using my Caps Lock key for Backspace even though that's been its function on my keyboard for weeks. Somehow I was able to train myself to learn a completely different layout, but something about Backspace (Delete on Macs) is just instinctual.. Primal even. Kinda like how I've only ever used Left Shift and never Right (I am a lefty, though I'm not sure if it's a common thing for people to use only Left Shift).
Dvorak
Offline Tony
« Reply #10 on: Mon, 03 October 2011, 21:53:09 »
I am a Colemak user and I replace Capslock with Backspace. Now I have two Backspaces, you have choice to use either hand to press Backspace.
Offline sam113101
« Reply #11 on: Tue, 04 October 2011, 12:00:28 »
Quote from: tony;425810
i am a colemak user and i replace capslock with backspace. Now i have two backspaces, you have choice to use either hand to press backspace.
SO YOU NEVER USE CAPS LOCK, right? Sad thing.
« Last Edit: Tue, 04 October 2011, 12:04:28 by sam113101 »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #12 on: Tue, 04 October 2011, 12:09:22 »
I have the Caps Lock function assigned to Win-Caps.  Even tho I have yet to find another purpose for the Caps lock itself.  I've never had a use for CapsLock tho...
Filco w/ Imsto thick PBT
Offline appie747
« Reply #13 on: Tue, 04 October 2011, 16:12:46 »
I programmed the swap in AHK and it works fine both at home and at work. At home I still can get capslock with shift-capslock YOU SEE?
Kinesis Freestyle Incline (work), Compaq MX 11800 (browns), AlphaGrip AG-5 FOR SALE! (home)
Offline AUAnonymous
« Reply #14 on: Wed, 05 October 2011, 02:04:06 »
I used the windows registry to hard code my Capslock to be Left Control, and then in AHK made Control + Pause = Capslock, so Capslock key + Pause also toggles Capslock. The LED and everything else still works exactly as you'd expect it to, you just have an extra Control key in a more ergonomically friendly place. I'd highly suggest remapping your Capslock key to something more useful (Control, Backspace or even Escape for my fellow vim users out there).
Noppoo Choc Mini (MX Blacks) - First mechanical keyboard :D
Why don\'t you give Colemak a try? You\'ll like it, I promise.*
*Not a real promise
