Author Topic: Topre 10th anniversary editon  (Read 7031 times)
Offline eliOcs
« on: Wed, 05 October 2011, 13:51:37 »
Offline reusje
« Reply #1 on: Fri, 07 October 2011, 08:10:45 »
I would order one :smile:
Offline insilica
  • Keyboard Geeza
« Reply #2 on: Fri, 07 October 2011, 09:14:17 »
It wouldn't make sense because keyboardco already caries the 86U and 88. Though I really wish they had the 87U (45g uniform of-course :)) and in ANSI - not fussed about the anniversary edition :) unless there is a uniform 45g ANSI of the anniversary edition :) which looks unlikely looking at the listings on some websites. There will be many takers, I for one will definitely put an order in :-)
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline itlnstln
« Reply #3 on: Fri, 07 October 2011, 09:18:15 »
If the price premium isn't ridiculous, I might consider one just because the caps look awesome.  You would figure that for a 10th anniversary 'board, they would do something more "special."  This is just an existing 'board with different caps and LEDs.  Meh.
Offline hcry4
  • HHKB Hoarder
« Reply #4 on: Fri, 07 October 2011, 10:15:24 »
30g instead of 35g is kinda special...
Offline hcry4
  • HHKB Hoarder
« Reply #5 on: Fri, 07 October 2011, 15:39:40 »
Sure, blow on them...
