Author Topic: I would like keycaps low profile for 6gv2 Where can I find.  (Read 4234 times)
Offline superbank
« on: Thu, 06 October 2011, 01:00:09 »
I would like keycaps low profile for steelseries 6gv2 Where can I find.
ps.shift right small many problems for me.
Thank you very much.
« Reply #1 on: Thu, 06 October 2011, 04:39:24 »
This would be a difficult task.
Keycaps from Cherry keyboards and new custom key caps from Signature Plastics (see 7bits group order thread) are lower than SteelSeries' caps. I still would not call them "low profile" though. They are only 1.5 - 2 mm lower than Steelseries'.
The biggest problem will be getting key caps in the Steelseries' layout: especially the "bigass" key.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Tue, 11 October 2011, 19:12:49 »
what do you mean by low profile? you can make a filco compatible set of keys work on a SteelSeries with a bit of work. Id Suggest WAS because you can get the Extra keys you need.
