Author Topic: need to know what keyboard is smaller in the KEY SPACING only  (Read 3280 times)
Offline eosgreen
« on: Fri, 07 October 2011, 16:29:09 »
so im deciding between a noppo choc mini and a deck 82
its so in sc2 i can hit the f keys without lifting my hand off the keyboard
i have to be able to hit ctrl and f1->4 while holding ctrl
basically i cannot find a dimension for the keys only nor the spacing between them
btw first post here obviously... recommended from OCN :)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Fri, 07 October 2011, 16:52:21 »
The 2 board you specified are the same in that regard.
Filco w/ Imsto thick PBT
Offline eosgreen
« Reply #2 on: Fri, 07 October 2011, 17:04:49 »
the keys for the deck 82 tho are not as large? u sure this is the case?
Offline fuzzyx3000
« Reply #3 on: Fri, 07 October 2011, 17:07:50 »
one thing you should probably consider is that the deck only has cherry mx blacks for its deck 82 whereas the choc mini has most of the switches save for maybe clears.
Offline eosgreen
« Reply #4 on: Fri, 07 October 2011, 17:12:07 »
Quote from: fuzzyx3000;427225
this is my first mechanical keyboard wana school me on why thats important?
Offline pyro
« Reply #5 on: Fri, 07 October 2011, 17:30:28 »
There's a wiki for that.
http://geekhack.org/showwiki.php?title=Cherry+switches+and+boards
Basically, mx blacks require more force to actuate than i.e. mx reds.
Simply remapping Capslock to Control would solve your problem though, unless you need that for something else.
Offline Glockateer
« Reply #6 on: Fri, 07 October 2011, 17:32:34 »
I guess I'm lucky to hit ctrl and F1-F8 with one hand on a normal keyboard. If you can adjust to the ctrl & capslock switch on the choc mini then you could reach even further.
Offline eosgreen
« Reply #7 on: Fri, 07 October 2011, 17:39:14 »
yeh i was always wondering about remapping useless caps lock but it would take some getting used to
what about mx browns? do those require more force?
Offline alaricljs
« Reply #8 on: Fri, 07 October 2011, 17:40:45 »
brown is equivalent to red in force required, it's got small tactile bump as compared to the linear red.
Offline eosgreen
« Reply #9 on: Fri, 07 October 2011, 17:41:47 »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250856182331&category=33963&_trksid=p5197.c0.m619
http://www.ebay.com/itm/330611595021?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
are the 2 keyboards im choosing between so then brown is technically superior for the person who doesnt want to use more force to hit the key
i think brown is up my ally
im getting a mechanical keyboard so my actual keystrokes dont get messed up and not recorded like on a membrain style cheapo board
i dont need anything extra so whats the tactile bump exactly?
nvm found the answer... i do NOT like tactile bump what are my options to not have this happen... im already trying to silence my board with those foam things so anything similar to tactile feedback is MOST unwanted and a dealbreaker
Offline alaricljs
« Reply #10 on: Fri, 07 October 2011, 21:49:14 »
Ok Blue's *click* and have some physical feedback.  Browns do NOT click but have physical feedback.  Blacks are stiff with no tactility at all, reds are less stiff with no tactility (this is linear).  Then there's also clears which are stiff like blacks, tactile bump that's harder than browns, and no click (also very few boards available).
Since you're playing sc2 and given your current opinion about tactility I'm betting everyone will be suggesting reds.  I still say browns tho :)
With or without foam pads or o-rings or whatever the keyboard will still make noise.  If you have silent switches (brown, clear, black, red) then the noise will come from the keycap bottoming out and topping out.  You can apparently learn not to bottom out (I will never bother).  As for topping out... nobody really has an answer as far as I've seen.
Offline slueth
« Reply #11 on: Fri, 07 October 2011, 22:09:40 »
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/mechanical-keyboard-noppoo/new-white-noppoo-mini-mechanic/lid=19308307
Get that.  Sexy, great for sc2, keys feel great.
If you have questions ask qtan in his store's sub forum. Most pros use browns for sc2.
Offline SmallFry
« Reply #12 on: Fri, 07 October 2011, 23:09:11 »
Welcome to GeekHack, firstly. Get bigger hands:P I second the remapping of caps lock and control.
Offline Glockateer
« Reply #13 on: Sat, 08 October 2011, 02:47:04 »
You don't need to remap ctrl+capslock on the choc mini. There is a "Switch" key to do it for you if it is what you prefer.
Offline Lanx
« Reply #14 on: Sat, 08 October 2011, 12:14:11 »
sounds like OP wants a mini with reds (does it come like that?).
