Author Topic: Switch Opener  (Read 5518 times)
Offline pyro
Switch Opener
« on: Tue, 11 October 2011, 17:22:11 »
This is what I use to open switches / pull keys. Though you have to be careful to not scratch the keycaps.
Offline RColinTaylor
Switch Opener
« Reply #1 on: Wed, 12 October 2011, 02:14:20 »
This isn't too bad of a design for a make-shift puller. If the scratching became a concern you could use something like electrical tape, melted a little bit, around the bend/tip to give it a sort of 'padding'.
I like my Browns more than my Blues.
