Author Topic: rosewill 9k blues, 100bucks and 20 gift card  (Read 2332 times)
Offline Lanx
« on: Thu, 13 October 2011, 06:14:40 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201040&nm_mc=EMC-IGNEFL101311&cm_mmc=EMC-IGNEFL101311-_-EMC-101311-Index-_-Keyboards-_-23201040-L012C
newegg
free shipping
cherry blues
100 and you get 20$ gift card... essentially making it 80bucks... VERY highly doubt you won't be able to find something you want on newegg in the near future.
Offline slueth
« Reply #1 on: Thu, 13 October 2011, 07:19:14 »
Nice find lanx, I think this will help a buddy of mines.
http://www.newegg.com/Product/Product.aspx?Item=N82E16823162015
81 dollars after rebate, i think the quality is about the same as wasd.
« Last Edit: Thu, 13 October 2011, 07:24:42 by slueth »
Offline Oqsy
« Reply #2 on: Thu, 13 October 2011, 08:18:04 »
WASD, Filco, etc.
A small number of controller issues are out there. It doesn't appear to be a problem with a majority of the boards, but it's worth mentioning so that yr friend can test his for the reported issues and RMA if needed before time runs out. (some are key combo oddness that one might not stumble across until the RMA period has passed).
All that aside, they're damn fine boards, and for the money, only WASD is comparable. ;)
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline Lanx
« Reply #3 on: Thu, 13 October 2011, 15:16:32 »
it's cheap even if you just want switches to mod!
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #4 on: Thu, 13 October 2011, 17:33:44 »
Thanks man, I am going to pick one of these up.
Offline Lanx
« Reply #5 on: Thu, 13 October 2011, 17:42:32 »
idk about rosewill keyboard quality, oddly enough they make shredders?! and this 30$ so far is the only shredder that can take a beating, and i've bought at least 1 50$ shredder from staples every 6months, they all break down (the plastic gears melt) staples/fellows whatever brand (i can't bring myself to buy a 200$ shredder), but this rosewill shredder awesome!
Offline Pretendo
« Reply #6 on: Sun, 16 October 2011, 03:50:11 »
Quote from: Lanx;430489
Rosewill is just a newegg in-brand.  These keyboards are produced for them by Filco as evidenced by the branding on the controller boards.  Though there seems to be a few shoddy controller boards in the bunch, I can say from personal experience that they are high quality keyboards.
IBM Model F-122 6110347 -- September 13th, 1984
IBM Model M 1391404 -- April 14th, 1988
Rosewill RK-9000
