Author Topic: what type of oil/grease used in mx switches?  (Read 1723 times)
Offline firewarrior
« on: Fri, 14 October 2011, 01:23:12 »
What is the grease or oil that is in the MX switches? I opened one up from a new keyboard and it was oily and was wondering what they use in case something ever drys.
Offline slueth
« Reply #1 on: Fri, 14 October 2011, 01:53:52 »
spit and duck fat
Offline daerid
    • Rossipedia
« Reply #2 on: Fri, 14 October 2011, 02:07:08 »
Haha
I use this stuff. Works like a charm.
« Reply #3 on: Fri, 14 October 2011, 03:20:14 »
Quote from: daerid;430782
Haha
Not inside the switch? You mean for the stabilizers, right?
Offline Clickey
« Reply #4 on: Fri, 14 October 2011, 05:07:45 »
I have used silicon oil and had mixed results on different switch types. You can get it in pen form from Fry's, which makes it really easy to apply small amounts accurately (you don't want to add to much or it will actually clog the switch/slow it down).
"we are on Geekhack not Lazy****" - The Solutor
