Author Topic: Filco rubber feet stick so well they collapse  (Read 2101 times)
Offline ownerer
« on: Fri, 14 October 2011, 12:02:46 »
So, my 104 Filco Ninja has rubber on the feet, and instead of preventing the board from moving, it just makes the left foot collapse. I can remove the rubber from the feet so they will slide instead of collapse, but then there is hardly any traction at all. Are there any quick fixes to the collapsing? It seems like if they were angled just slightly more they wouldn't collapse so easily. It's only one foot, is this a defect?
Offline itlnstln
« Reply #1 on: Fri, 14 October 2011, 12:06:19 »
Filcos suck.  Off-center cases, key caps that go shiny, ping, and collapsing feet.  You should get a refund and get an Xarmor instead.
(No. In fact, it's probably just working too well.  Try putting a piece of rubbery shelf liner underneath it to keep it from sliding altogether.)
Offline redpill
« Reply #2 on: Fri, 14 October 2011, 12:11:38 »
I had a similar issue, only the rubber feet themselves would just fall off.  It would have been more effective for the feet to click and lock open, and then more securely affix the rubber.  But whatever, Filcos are the best blahblahblahblahblah
« Last Edit: Fri, 14 October 2011, 12:15:06 by redpill »
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded Keycaps |  Ducky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline Chobopants
« Reply #3 on: Fri, 14 October 2011, 13:10:18 »
Board flat with Filco wrist rest, no problems. :)
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline itlnstln
« Reply #4 on: Fri, 14 October 2011, 14:13:20 »
Quote from: Chobopants;431147
That's how I roll.
Offline Mazora
« Reply #5 on: Fri, 14 October 2011, 14:48:05 »
Quote from: ownerer;431071
Your avatar shows a pylon block. Unfortunately, its on a noob map !:)
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline duncan
« Reply #6 on: Fri, 14 October 2011, 18:11:05 »
Sucks you are having trouble with such an expensive bit of kit.
Try not using the feet extended for a week and see how it feels.
I used to always use feet but an ergo expert suggested it was part of the cause of some pain I was having and having stopped elevating boards I have been much happier for all sorts of reasons. Now I never use the feet on any board. Flat is far better for me once I got over the initial shock of change.
Doesn't make up for what might be a slightly badly built board but maybe you will find it is the trigger to lead you to a better typing experience by an unfortunate path.
Realforce 86UB || HHKB P2 || FILCO MT 87 Blues || FILCO MT 87 Browns || FILCO MT 87 Ninja  Blacks || Poker X Reds
Offline ownerer
« Reply #7 on: Sat, 15 October 2011, 12:02:20 »
Quote from: ripster;431404
Maybe you have it set up too high.
I don't see how the elevation would effect the functionality, but thanks for the wisdom. I have money to spend on keyboards, unfortunately not desks.
Offline Clickey
« Reply #8 on: Sat, 15 October 2011, 12:23:28 »
Quote from: ownerer;431743
If you wanted, you could lower your keyboard tray by screwing it in lower down (assuming is uses screws).
"we are on Geekhack not Lazy****" - The Solutor
Offline sinis
« Reply #9 on: Sat, 15 October 2011, 12:53:21 »
Filcos have feet?
german filcos only have meters!!!!11   ^^
Offline sinis
« Reply #10 on: Sat, 15 October 2011, 13:10:38 »
???... think Im not old enough for this one...  >_<
