Author Topic: Red ESC / WASD to Blackwidow Ultimate  (Read 2306 times)
Offline tukkez
« on: Fri, 14 October 2011, 13:19:35 »
Hey,
Thinking of getting some red WASD keys and a different ESC button to my Blackwidow Ultimate. Which should I get and where?  Do all the Cherry MX keys work in Blackwidow Ultimate? Thanks.
Found some Filco Red "WASD" keys, Would these work?
http://www.silentrig.com/product/1239/filco-red-wasd-keys
Offline noodles256
  • le legendary
« Reply #1 on: Fri, 14 October 2011, 13:21:46 »
wlcm
AF | Ducky YOTD |
Offline enoy21
« Reply #2 on: Fri, 14 October 2011, 15:34:58 »
Depending on where you are located there are different vendors. You can try Qtan in the group buy , he sells key caps international from Asia.  Or WASD Keyboards from here in the states sell a multitude of colors. I got a blue and yellow set from them and they are great.  ( Although unused because I found them distracting and the board felt unbalanced aesthetically. )
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline tukkez
« Reply #3 on: Fri, 14 October 2011, 15:50:44 »
How do I know which key caps / keys work with Blackwidow Ultimate? Are they a completly different key or just some kind of sticker that you put on the original key ?
« Reply #4 on: Fri, 14 October 2011, 16:46:36 »
As long as they are designed to fit the cherry stem (keycap description will say its for cherry mx switches.) you can use it with your board.
Also, I think I read something about razer saying that you void your warranty if you take out the keycaps? I hope that's not true or else that'd be the dumbest **** ever.
Offline tukkez
« Reply #5 on: Fri, 14 October 2011, 21:16:05 »
I'm fairly sure that's not true. How would they know if I took off a key? :D
Offline simon_C
« Reply #6 on: Fri, 14 October 2011, 21:52:40 »
Quote from: noodles256;431157
wlcm
why do you keep doing this? have you forgotten what vowels are? are you just trying to pad postcount? i see you posting 'responses' like this in multiple threads.
