Author Topic: 1st Mech Keyboard Ever  (Read 7116 times)
Offline Lmnr
  • The Jack Of All Trades
    • W.W.C.
« on: Fri, 14 October 2011, 22:45:56 »
So up to a couple months ive been researching heavily on which brands are well known and which ones arent. Ive narrowed it down to the 87u and a filco. But for the price they arent exactly in my budget so I was looking at cheaper companies such as das or ducky and I came up for das the Ultimate silent version and for the ducky i was intrigued by the 9008g2 model. For the price and its reputation isint that bad from what ive heard not like the 1008 the g2 seems to be built better so I went with the dk9008g2 Rabbit Limited which is a white on white keyboard plus its got brown switches. I like to game alot and I have pretty much never played with a mech keyboard I wouldnt know the difference. Currently im not playing anything that fast paced but I regulate from unreal tournament-quake and sometimes rts like red alert or even sc. I recently found a IBM kb-3923 its a membrane but its got a better feel than most of the membrane keyboards ive used current ones I have are the sidewinder x6,Fatal1ty scissor keyboard(idk what the name is exactly but its a ok keyboard)anyways...
 Topre - 87u,Filco - ninja,Das - Ultimate Silent,Ducky - 9008g2 rabbit,IBM - Model M
Theres others that I dont hear much about as for the switches ive narrowed it down to the best topre then brown and then red. Only problem is that I live in the us and i cant really try any keyboards myself and the ones I remember using a while back is the model m. Specially the topres since ive heard videos of them and heard good things but I CANT TRY THEM OUT MYSELF. So far ive tried the blackwidow which i hate cause it just looks so cheaply made and I really dont like blue switches. The one that intrigued me the most was probably the ducky since supposedly the 9008 models are up to standard with the filcos which is a big plus. The design of it is pretty unique and the price 132$ + 15 bucks shipping sounds like a good deal. I just need some thoughts, yes I am new and ive never had a membrane but for some reason ive grown to the sound of mech keyboards typing it was like a flashback plus theyre better keyboards overall.
Peripherals:
Realforce 87uw with grey caps,Ducky YOTR Blues,Realforce 104ug Hipro,Zowie Am FG,WMO 1.1a,Sidewinder X3
Offline slueth
« Reply #1 on: Fri, 14 October 2011, 22:51:06 »
nice wall of text ;d welcome to geekhack. I didn't see a question in there.
Offline pitashen
« Reply #2 on: Fri, 14 October 2011, 22:53:59 »
didn't bother reading whatever you typed up there. But, have fun!
Offline Lmnr
    • W.W.C.
« Reply #3 on: Fri, 14 October 2011, 22:57:04 »
Lol I just need some thoughts on which keyboards to get.
Peripherals:
Offline F u r u y á
« Reply #4 on: Fri, 14 October 2011, 23:00:12 »
You can get Filco for $140 in amazon.
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline Lmnr
    • W.W.C.
« Reply #5 on: Fri, 14 October 2011, 23:02:12 »
Ive heard that blank black keys get really shiny after a short while
Peripherals:
Offline Lmnr
    • W.W.C.
« Reply #6 on: Fri, 14 October 2011, 23:03:25 »
at least the filco I wanted was like that
Peripherals:
Offline noodles256
  • le legendary
« Reply #7 on: Fri, 14 October 2011, 23:32:21 »
Wlcm
AF | Ducky YOTD |
Offline F u r u y á
« Reply #8 on: Fri, 14 October 2011, 23:33:05 »
yeah, Filco has ABS keycaps (gets shiny), but you can get some PBT later on... or pick a keyboard which comes with PBT stock. Ducky has it if I'm not mistaken.
Offline Lmnr
    • W.W.C.
« Reply #9 on: Fri, 14 October 2011, 23:34:53 »
hmm oh ok but has anyone heard of ducky's 9008 model being up to par with the build quality of filcos?
Peripherals:
Offline Lmnr
    • W.W.C.
« Reply #10 on: Fri, 14 October 2011, 23:59:56 »
http://global.pchome.com.tw/DCAH0X-A58314153 specifically that model since the year of the tiger one isint for sale anymore?
Peripherals:
Offline Fuzzy Dunlop
« Reply #11 on: Sat, 15 October 2011, 00:41:47 »
Welcome to Geek Hack :)
Have you visited Newegg.com? The Rosewill RK9000 is a good deal for $99. It's unfortunate, but mechanical switches cost more to manufacture than rubber domes. As a general rule of thumb you're looking around $100 and up for a mechanical keyboard. If you're in the U.S., elitekeyboards.com have the Leopold for $109. Same designer as the Filco, same parts, arguably better key stabilizers, $50 less than a Filco. Or for another $10 you could of course order something completely custom form wasdkeyboards.com. The lowest you are going to find a Topre is in the $180-$200 range. I've had a variable weighted 86UB for around 3 weeks now, I'm very happy with it. The most noticeable differences between the 86 and newer 87 series are the 87's (moderately) quieter switches and LEDs in the ctrl/caps/scroll lock keys. Are LEDs and silencers really worth an extra $80? I'm not so sure.
Topre ReɅlforce 86UB   |   Razer DeathAdder Black Edition
Offline kingqway
« Reply #12 on: Sat, 15 October 2011, 01:49:27 »
Paragraphs, please... paragraphs!!
lol, but in all seriousness, I have a Das & Leopold, and if I could point you to something: unless you like the look of the das, I would probably get the leopold. The Leopold feels a little more sturdier than the Das, but all in all they're both great keyboards. Their main difference being looks & stabilizers. Though buying a used Das would probably save you some money if you could find one (and be a good intro keyboard), since people don't try too hardcore to collect them like they would filcos. Before you pick between these two though, just make sure to double check what kind of stabilizers you would like, cherry stabilizers like the Leopold or the Costar ones in Filcos & Das, etc.
The reason people don't like the cherry stabilizers is because, in my opinion, it takes away from the "mx switch" & tactile feel that the normal keys (I use MX Brown) have, in return for making the key much more stable than costar ones, thus complaints about it's "mushiness". It makes sense, since a lot of people buy mechanical keyboards for that mechanical switch feel, so in some sense it is pointless to reduce that level of interest. Personally I like both of them, and they both have their ups and downs.
If you play FPS more-so then RTS, I would look more into browns or reds (blacks if you don't mind using the keyboard solely for heavy gaming).
Das Professional Silent || White Filco TKL MX Blue || Leopold FC500R MX Brown
Offline Pretendo
« Reply #13 on: Sat, 15 October 2011, 02:17:18 »
Rosewill RK-9000 has been treating me right these past few days, only $99 at newegg ( and a little more for Cherry reds.)  That's basically a Filco made board and would make for a fantastic entry into the mechanical keyboard world!  Fuzzy Dunlop already said this, but second his opinion.
Also, if you order before next weds I think they're throwing in a $20 gift card and free shipping.  Get on that, son!
IBM Model F-122 6110347 -- September 13th, 1984
IBM Model M 1391404 -- April 14th, 1988
Rosewill RK-9000
Offline Lmnr
    • W.W.C.
« Reply #14 on: Sat, 15 October 2011, 08:45:37 »
LOL with the paragraph thing I didn't think it was something too big for people to read anyways.. ill check it out
Peripherals:
Offline peda
« Reply #15 on: Sat, 15 October 2011, 09:11:33 »
Quote from: kingqway;431559
Now I finally know the reason for big ass enter keys: due to the size people don't forget to use it.
There you go us-boys...  European design is superior :-P
Offline Lmnr
    • W.W.C.
« Reply #16 on: Sat, 15 October 2011, 10:19:03 »
LOL bashing on a newbie for not paraphrasing :D
Peripherals:
Offline simon_C
« Reply #17 on: Sat, 15 October 2011, 10:51:59 »
Well, this is a keyboard site. ;)
also, your avatar is creeping me out...
Offline Lmnr
    • W.W.C.
« Reply #18 on: Sat, 15 October 2011, 12:20:40 »
LOL enderman ftw
[video=youtube;QhqfniaERAY]http://www.youtube.com/watch?v=QhqfniaERAY[/video]
Peripherals:
Offline sinis
« Reply #19 on: Sat, 15 October 2011, 12:23:21 »
I clicked on 1080p but it was that pixeled anyway lol
Offline Lmnr
    • W.W.C.
« Reply #20 on: Sat, 15 October 2011, 12:27:00 »
lol pre-release was somewhat laggy plus 120 fov while I recorded :D
Peripherals:
Offline sinis
« Reply #21 on: Sat, 15 October 2011, 12:28:20 »
keeps crashing on my machine.
Offline Lmnr
    • W.W.C.
« Reply #22 on: Sat, 15 October 2011, 12:31:13 »
what are your specs?
Peripherals:
Offline sinis
« Reply #23 on: Sat, 15 October 2011, 12:35:44 »
gtx 570
core i5
8gig RAM
lol minecraft is a hardware eating beast
edit: OS is Win7 64bit professional
« Last Edit: Sat, 15 October 2011, 12:37:57 by sinis »
Offline Lmnr
    • W.W.C.
« Reply #24 on: Sat, 15 October 2011, 12:39:12 »
Yep lol 6870 here i7 870 and 8gb ram and mine with highest settings plus far rendering I end up with like 50 fps
Peripherals:
Offline enoy21
« Reply #25 on: Sat, 15 October 2011, 13:32:46 »
Leopold is generally considered a cheaper , more feature laden version of Filco. Uses cherry stabalizers.
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline spolia optima
« Reply #26 on: Sat, 15 October 2011, 14:07:24 »
You sound like you want the best.
So... I'd say Topre. Last keyboard you'll ever need to buy.
keyboards!
Offline sinis
« Reply #27 on: Sat, 15 October 2011, 14:21:50 »
Quote from: Lmnr;431781
LoL is my most played game at the moment. Probably till BF3 is here. Didnt try minecraft for quite some time tbh.
To talk about your keyboard:
I used a second hand cherry mx black from ebay that went for 10 bucks to me. After some time and money gathered, I bought a new Filco brown MX then. Because it was the only choice for brown MX here that is tenkeyless. No used ones. No browns. No tenkeyless.
If you have the possibility to get a (used) tenkeyless MX brown you will love it imho.
The used market is very big. People try switches all the time and sell the boards then. But not for MXbrown boards lol.
Filco is fine. But I would have picked up any 6KRO tenkeyless board with a good reputation. Good reputation for reselling it if I dont like it. Like Leopold, Ducky... dont ask me for the KRO at this boards. Filco was just the easiest to get and not much more expensive.
have fun while shopping ^^
edit PS: I would love to get my hands on an all 45g topre tenkeyless or even an HHKB. Used or new. But out of my reach for a looooong time. And the Layout of Realforce is more comfortable than HHKB imho.
« Last Edit: Sat, 15 October 2011, 14:29:12 by sinis »
Offline Lmnr
    • W.W.C.
« Reply #28 on: Sat, 15 October 2011, 14:37:55 »
If it was a topre should I get the all 55g or the variable one (86u or 87u)
Peripherals:
Offline sinis
« Reply #29 on: Sat, 15 October 2011, 14:45:15 »
Well you shell not kill. But in case of topre I cant find no line. Still searching though xP
« Reply #30 on: Sat, 15 October 2011, 14:53:36 »
Quote from: Lmnr;431846
variable. the difference between weights is subtle.
keyboards!
Offline Lmnr
    • W.W.C.
« Reply #31 on: Sat, 15 October 2011, 16:12:35 »
Hmm does anyone know if black friday deals affect any keyboard companies in the past?
Peripherals:
« Reply #32 on: Sat, 15 October 2011, 17:14:32 »
There were Rosewill deals last year iirc
keyboards!
Offline Lmnr
    • W.W.C.
« Reply #33 on: Sat, 15 October 2011, 17:20:29 »
LOL im really REALLY hoping that theres some deals on topres...
Peripherals:
Offline slueth
« Reply #34 on: Sat, 15 October 2011, 17:23:48 »
the ducky 9k series is better then the 1k ones.  You can get that at pchome.
Offline enoy21
« Reply #35 on: Sat, 15 October 2011, 17:30:08 »
Also , If you don't need Tenkeyless, You can always get a WASD with custom keycaps to really make it your own.  I love my WASD board , but I wish I had gotten browns instead of Blues.  AND I wish they offered Tenkeyless.   Hopefully when I'm ready to try reds they i will have TKL by then.
WASD 104 work
WASD 104 home
Offline N8N
« Reply #36 on: Sat, 15 October 2011, 17:31:16 »
Really, I wish that WASD offered clear switches.  Wouldn't be any need to buy anything from anyone else in that case, just swap the spring and stem in the space bar switch for a grey one and you'd have a damn near perfect keyboard.
Offline Lmnr
    • W.W.C.
« Reply #37 on: Sat, 15 October 2011, 23:34:01 »
So anyone know if topre has sales at one point of the year?
Peripherals:
« Reply #38 on: Sun, 16 October 2011, 00:11:14 »
Quote from: Lmnr;432081
i doubt it.
EK has sales from time to time though. A while back the Realforce 103UW was on sale for $199 iirc. I really regret not picking one of those up.
keyboards!
Offline Lmnr
    • W.W.C.
« Reply #39 on: Sun, 16 October 2011, 00:20:07 »
sigh... umm 217$ plus 24$ shipping good deal for a 86UB tenkey?
Peripherals:
Offline Lmnr
    • W.W.C.
« Reply #40 on: Sun, 16 October 2011, 16:24:18 »
Quote from: spolia optima;432107
i doubt it.
http://forums.redflagdeals.com/keyboard-realforce-103u-uw-white-gray-215-sale-997095/
That one was 215$ :(
Peripherals:
