Author Topic: color comparison: wasdkeyboards red vs elitekeyboards red (cherry mx caps)  (Read 6168 times)
Offline absfac
Just got a pack of key caps from wasdkeyboards and I thought I'd post a pic comparing the red tone with the red key cap that came packed free with leopolds from elitekeyboards (I didn't see an existing thread on this).
The center is the free red key cap from EK; it's flanked by two red caps from wasdkeyboards. (Pardon the dust.)
http://imgur.com/xK2ci
All other key caps in the picture are stock from the FC200RC/ABN.
The EK red cap is a substantially deeper red, whereas the wasd version has a slightly orange cast.  For best viewing, stand a little back from the monitor; up close your eyes will average the red tones together.  In person the difference is even more dramatic.  They both look good, but you won't really be able to mix and match them side by side unless you want the color difference.
I'm not too surprised. Color matching for industrial products is hard. Still I thought this might be useful information for newbies, especially as in the US I expect many will get their start by ordering from EK and then adding some caps from wasd.
Hope this helps.
« Last Edit: Sun, 27 November 2011, 12:18:02 by absfac »
Offline nikonf5
« Reply #1 on: Sat, 15 October 2011, 16:41:41 »
There is a thread elsewhere in the WASD forum in which he mentions he will be getting more colors in and he lists the ones he will more than likely be getting in and one of them is a deeper red.
« Reply #2 on: Sun, 16 October 2011, 00:03:45 »
Quote from: nikonf5;431922
http://geekhack.org/showthread.php?21709-Keycap-Colors&p=411878&viewfull=1#post411878
-Purple
-Darker Gray (Charcoal)
-Darker Red
-Lighter Blue
-Darker Green
-Pink
I'm interested in darker grey, darker red, and darker green. It's gonna be awesome.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #3 on: Mon, 24 October 2011, 06:25:29 »
Quote from: dorkvader;432102
same here but also the lighter blue pertaining its not too light and it the etching mates the red and green ok.
