Author Topic: Weighted Keyboards  (Read 1873 times)
Offline HeavyArms
  • "Lit"
Weighted Keyboards
« on: Tue, 18 October 2011, 02:17:29 »
I really love the weight my Filco has to it, doesn't move at all and a solid keyboard. Does anyone know any other mechanical keyboard brands that have that same weighted feel I should explore?
Head in the clouds.
Offline daerid
    • Rossipedia
Weighted Keyboards
« Reply #1 on: Tue, 18 October 2011, 02:20:38 »
Pretty much anything plate-mounted will give some semblance of that feel, depending on the material of the plate. I found that the PLU ML87 didn't quite feel as solid as the Filco, but the Das Keyboard was almost indistinguishable. However, one of the reasons I feel that Filcos feel so solid on the desk is the rubberized popup feet. Those make a huge difference in how the board feels.
Offline litster
  • rare caps?! THAT'S A SMILIN
Weighted Keyboards
« Reply #2 on: Tue, 18 October 2011, 02:32:35 »
I get these rubber feet from Radio Shack http://www.radioshack.com/product/index.jsp?productId=2103342
I stick two to the rear bottom of each of my 87U keyboards.  The already solid 87U now is even more stable.
Offline spolia optima
Weighted Keyboards
« Reply #3 on: Tue, 18 October 2011, 02:51:08 »
Minus the Kbc Poker and G80, Just about all the popular mechanicals made today are plate-mounted
keyboards!
Offline hawkwind
Weighted Keyboards
« Reply #4 on: Tue, 18 October 2011, 06:40:03 »
IBM Model F
Offline Maarten
Weighted Keyboards
« Reply #5 on: Tue, 18 October 2011, 06:44:32 »
I only got 1 mechanical atm (6Gv2), but its pretty hefty; 1.2kg :D
Offline HeavyArms
  • "Lit"
Weighted Keyboards
« Reply #6 on: Tue, 18 October 2011, 11:18:38 »
Thanks for the responses.
Head in the clouds.
Offline mmmty
  • bang! bang!
Keyboardless
