Author Topic: Vacuforming keyboard cases?  (Read 1923 times)
Offline whiskerBox
« on: Tue, 18 October 2011, 10:21:11 »
Does anyone here have vacuforming experience?
Here is what I was thinking, we could create clear keyboard cases by using this process
Building a Vacuumform Table (http://www.studiocreations.com/howto/vacuumtable/index.html)
 and The Basics of Vacuumforming (http://www.studiocreations.com/howto/vacuumforming/index.html)
Maybe with materials like these
[ Attachment Invalid Or Does Not Exist ] 28915[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 28917[/ATTACH]
material link and pricing
The whole goal would be to replicate this look, but with whatever keyboard you wanted.
[ Attachment Invalid Or Does Not Exist ] 28916[/ATTACH]
I am personally thinking of attempting to do this on a Filco
« Last Edit: Tue, 18 October 2011, 10:23:36 by whiskerBox »
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline whiskerBox
« Reply #1 on: Tue, 18 October 2011, 10:37:35 »
Quote from: ripster;433568
.08" is pretty thin.  You'd have to suck harder than Linda Lovelace for acryllic.
well in addition to 1/8" they also have 1/4", but its obviously a little more expensive($28.84 for 1/4" x 12" x 24"). I just assumed that the thinner 1/8" sheet would be easier to form, but I've never done this before.
Obviously I will just try the cheapest acrylic I can find first until I figure out how to do it because **** ups @ $28 a pop would suck
« Last Edit: Tue, 18 October 2011, 10:45:43 by whiskerBox »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Tue, 18 October 2011, 10:57:51 »
The point was that vacuum forming is done with ~.08" thick sheets of low melting point platic.  You're talking about trying it with either .125" or .25" thick sheets of acrylic that have a much higher melting point.  You're not going to vacuum form that stuff with a shop vac.  Doubt there's anyone that vac-forms the stuff.  Besides that picture of the acrylic KB is all cut sheet.
Filco w/ Imsto thick PBT
Offline whiskerBox
« Reply #3 on: Tue, 18 October 2011, 11:18:16 »
Ok this is the type of stuff I need to know, so basicaly I wouldn't be able to vacuform anything of a thickness that would be worth making a keyboard case out of!
Maybe Dust Covers? LOL.
Offline alaricljs
« Reply #4 on: Tue, 18 October 2011, 11:38:47 »
Yes, the Filco dust/shipping cover is a perfect example of something that's been vacuformed.  Also if you're into model airplanes or cars you can vacuform canopies and bodies  :)
Offline alaricljs
« Reply #5 on: Tue, 18 October 2011, 11:40:41 »
If you do want to form acrylic sheet it's usually done with a torch and forms to force the shape.  Mostly this is just simple straight line bends, anything that's multi-axis is going to be done with a press and forms of some sort.
Offline whiskerBox
« Reply #6 on: Tue, 18 October 2011, 11:42:59 »
It all makes sense now, This will definitely not work for the application I was thinking of.
