Author Topic: Keyboard with left alt closer to the middle ?  (Read 3155 times)
Offline bbbbqq
« on: Wed, 19 October 2011, 01:18:22 »
Does it even exist ? the left alt key on every keyboard I can see is between the Z and the X. I'm looking for a keyboard with the left alt closer to the middle, say, between X and C. I use it a LOT, and having to stress my thumb the extra half inch or so is already killing my wrists, with less than hour on this keyboard.
The only board I can find with that is the MS natural 4000, which isn't mechanical (and what I'm switching from)
halppppp
Offline RColinTaylor
« Reply #1 on: Wed, 19 October 2011, 01:22:54 »
Off of the top of my head, no. And from the skimming of popular keyboard's designs, no. In my opinion the best option would be to remap the key to something else or become more accustomed to using the right-alt key.
I like my Browns more than my Blues.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #2 on: Wed, 19 October 2011, 02:37:49 »
Noppoo Choc Mini possibly...
« Reply #3 on: Wed, 19 October 2011, 03:05:06 »
Quote from: TheProfosist;434305
The choc mini has a standard alt-key placement.
« Reply #4 on: Wed, 19 October 2011, 03:05:57 »
Quote from: RColinTaylor;434311
but isnt the spacebar shorter
« Reply #5 on: Wed, 19 October 2011, 03:18:19 »
Yes, but the Windows Key is a 1x and not a 1.25x. And on the right side of the spacebar 3 of the modifiers are 1x and one ix 1.25x. All of this extra space goes towards fitting the arrow keys into the bottom row.
Offline biochem
« Reply #6 on: Wed, 19 October 2011, 08:22:54 »
Although it isn't mechanical, the Microsoft Natural keyboard has the left alt key below the X and C.
[ Attachment Invalid Or Does Not Exist ] 28999[/ATTACH]
Filco MJ2 tenkeyless (blues)
Heatware
« Reply #7 on: Wed, 19 October 2011, 08:25:52 »
Quote from: biochem;434392
(Attachment Link) 28999[/ATTACH]
That is the keyboard that OP is referencing in the first post. I think he wants a keyboard that would operate like a MS Natural but is mechanical.
Offline Brodie337
« Reply #8 on: Wed, 19 October 2011, 08:26:12 »
If you're using alt alot, maybe try using AutoHotKey to map caps lock to left alt?
Offline biochem
« Reply #9 on: Wed, 19 October 2011, 08:59:07 »
Quote from: RColinTaylor;434394
My mistake, should have read the whole post.
Heatware
Offline duncan
« Reply #10 on: Wed, 19 October 2011, 09:10:19 »
How about a JP layout board like this one:
http://www.pfu.fujitsu.com/hhkeyboard/hhkbprojp/
You could map those extra command keys as you like.
Realforce 86UB || HHKB P2 || FILCO MT 87 Blues || FILCO MT 87 Browns || FILCO MT 87 Ninja  Blacks || Poker X Reds
Offline Khenra
« Reply #11 on: Wed, 19 October 2011, 09:27:52 »
As Brodie said, you could remap Alt to a different key. I'd recommend the Windows key and use your pinkie to hit it.
[SIGPIC][/SIGPIC]
Filco Majestouch-2 Tenkeyless Cherry MX Brown
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Wed, 19 October 2011, 13:58:41 »
I also think a JIS board would be best since it has extra keys between alt and space, it should be ideal assuming they can be remapped. This Filco is another example.
Offline bbbbqq
« Reply #13 on: Wed, 19 October 2011, 20:18:20 »
Don't think a JP layout is for me, I like regular enter keys and not the backwards r shaped ones (and especially not the L shaped ones)
4 keys to the left of the spaceba would be nice though :(
Offline flyball
« Reply #14 on: Wed, 19 October 2011, 20:32:27 »
do you use alt more than control? try mapping it to caps lock
[SIGPIC][/SIGPIC]
