Author Topic: Question about IBM model M  (Read 1508 times)
Offline Serket
« on: Wed, 19 October 2011, 13:50:42 »
Hey guys, just a quick question for you guys who are more familiar with IBM model Ms.
I just got into the whole mech keyboard thing and realize that I actually used one of these boards a couple years ago. Suffice to say I realllllly liked it's feel, only at the time I had no idea what a buckling spring was all about.
So, I have decided to pick one up, but I wanted to know if there is a particular model I should look out for. I know that it was later made by lexmark and unicomp and those models are generally considered to be of poor quality right?
Is there any particular year or type of vintage IBM keyboards that can be considered the "best"? I know there's also a model F, but I don't really know the difference between them. Any info would be appreciated.
Thanks.
Offline Atenacius
« Reply #1 on: Wed, 19 October 2011, 13:56:44 »
If you check the wikipedia article on the Model M, it gives you a list of all the models and their features. What you should look for are whether or not they are terminal or PS/2 connections, detachable/non-detachable cords, drainage holes, 2 piece/1 piece keys and especially whether it's buckling spring or rubber dome.
http://en.wikipedia.org/wiki/Model_M_keyboard
I personally think they're all good whether it's Lexmark or Unicomp but watch out for those rubber domes. I good rule of thumb would be to avoid any model number with the letter 'G' in it.  Not all of them with 'G's are rubber dome but they aren't the best models anyway. The ideal model is 1391401 if it makes it easier for you.
« Last Edit: Wed, 19 October 2011, 13:59:16 by Atenacius »
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline Serket
« Reply #2 on: Wed, 19 October 2011, 14:54:22 »
Alright, that's excellent. I will definitely look out for that model number.
The point about the model numbers with G is also interesting, as I was not aware about that. Thanks alot.
