Author Topic: Ducky v Noppoo  (Read 4382 times)
Offline glycolate
Ducky v Noppoo
« on: Wed, 19 October 2011, 20:12:54 »
having a hard time deciding if i want the ducky tenkeyless or the noppoo mini. anyone have both brands,want to comment?think there is a quality difference between them?it'd cost the same for either board.
i know quite a few of you have good sized collections,so lemme know what you think.
Offline duncan
Ducky v Noppoo
« Reply #1 on: Thu, 20 October 2011, 04:16:18 »
If you aren't sure then get the Ducky.
The noopoo's non-standard layout is something you will love or loath so unless you are confident that you want to deal with it then get the Ducky so you have less new things to deal with all at once.
Realforce 86UB || HHKB P2 || FILCO MT 87 Blues || FILCO MT 87 Browns || FILCO MT 87 Ninja  Blacks || Poker X Reds
Offline spolia optima
Ducky v Noppoo
« Reply #2 on: Thu, 20 October 2011, 07:14:11 »
What duncan said
They're both cheap, but the non-standard layout of the Nopoo could be an annoyance for some folks.
keyboards!
Offline peda
Ducky v Noppoo
« Reply #3 on: Thu, 20 October 2011, 07:49:47 »
Quote from: spolia optima;435147
Or the oposite.
I really enjoy the layout of the noppoo but as stated, it is personal to the individual.
Offline itlnstln
Ducky v Noppoo
« Reply #4 on: Thu, 20 October 2011, 08:03:36 »
I would go with the Ducky as well.  I find that as a daily driver, I prefer a normal layout (except the HHKB).
Ducky v Noppoo
« Reply #5 on: Thu, 20 October 2011, 09:28:39 »
I like the layout too. It's just about perfect. Compact layouts are pretty much all around FTW
keyboards!
Offline glycolate
Ducky v Noppoo
« Reply #6 on: Fri, 21 October 2011, 07:56:21 »
im getting the noppoo now. ill probably grab the ducky around january.
unless i find a good alps before then.
Offline HWI
Ducky v Noppoo
« Reply #7 on: Fri, 21 October 2011, 23:55:54 »
I personally prefer my Choc Mini over the DK-1087 I had. I love the layout of the Choc Mini, quality wise they are pretty similar and I had premature keycap wear on both. From what I understand the new Choc Minis have corrected this problem.
Bottom Out Like A Boss
Razer BWU | Ducky DK-1087 | Noppoo Choc Mini | CM Storm QFR | KBT Race
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Ducky v Noppoo
« Reply #8 on: Sat, 22 October 2011, 01:26:01 »
I also like the Choc Mini layout.
Offline Uninstall
Ducky v Noppoo
« Reply #9 on: Sat, 22 October 2011, 04:24:55 »
I love the Noppoo as well, but you should be aware that you need to press the Fn key to access useful keys such as Home.
Offline Tony
Ducky v Noppoo
« Reply #10 on: Sun, 23 October 2011, 07:09:49 »
I would get Ducky if I were you. Noppoo has strange layout and I do not appreciate its portability much.
Offline slueth
Ducky v Noppoo
« Reply #11 on: Sun, 23 October 2011, 07:36:30 »
Noppoo ftw imo
Offline Marclgw
Ducky v Noppoo
« Reply #12 on: Sun, 23 October 2011, 08:02:58 »
Ducky have bad QC and a design flaw which they never wanted to correct. The esc keys is nor centered, its towards the left.
You cannot even fit the filco keycap puller in nicely, you have to apply a certain force due to the design flaw.
