Author Topic: Unicomp Space Saver: Right shift + X doesn't work  (Read 1335 times)
Offline Pixie
« on: Thu, 20 October 2011, 18:55:06 »
Hello geekhackers
As you can see this is my first post in this Forum
I'm Pixie from a smaaall European country with lots of chocolate, mountains and cows...
Anyway... a few months ago, I bought a Unicomp Space Saver (USB). I like it!
But today I've discovered something weird about it. The key combination of "right Shift" and X doesn't work! It doesn't make a small x, it just makes nothing ... but "small" x by itself and "left shift" + X works.
I don't think that's normal, is it?
Is there a way to fix that by myself or should I send it back to U.S. and A. ?
Cheers
EDIT: I just found out some other key combinations that don't work.
p+x
.+x
b+x
5+x
-(num block)+x
.(num block)+x
0(num block)+x
1(num block)+x
§(button below esc = `~ on US-layout)+x
Probably there are many more. And these one's don't bother me. Just FYI... But r-shift+X is important :/
Offline spolia optima
« Reply #1 on: Thu, 20 October 2011, 19:31:28 »
i'm not totally sure what you're talking about but yeah... that doesn't sound normal
welcome to geekhack btw!
keyboards!
« Reply #2 on: Thu, 20 October 2011, 19:33:28 »
Quote from: Pixie;435681
...and nazi gold?
keyboards!
Offline Pixie
« Reply #3 on: Thu, 20 October 2011, 19:40:10 »
Quote from: spolia optima;435694
Thanks.
Quote from: spolia optima;435696
...and nazi gold?
Yeah ... but sssshhhh! :tape2:
