Author Topic: Mechanical Numpads that work without Num Lock?  (Read 3290 times)
Offline nar
« on: Fri, 21 October 2011, 00:34:03 »
So after 2 weeks with my compact keyboard without a numpad, I realized I really need one in certain situtations. But this keyboard has the numpad keys overlayed on normal keys whenever Num Lock is enabled, so I need a numpad that works when Num Lock is disabled.
Any suggestions?
I'm open to any switch type, and something radically different from topres on the numpad may give an interesting experience (I gave up on a topre numpad, EK is selling them for more than my keyboard itself >_<).
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
Offline arplod
« Reply #3 on: Sun, 23 October 2011, 06:15:51 »
The Filco feels a bit 'off' - clatterier, I guess that's because the plate in there isn't heavy enough - when you line it up alongside even a Filco brown keyboard, but I can confirm it has independent num lock. I use them with laptops with num overlays and it works fine. You can see the num lock being triggered on the laptop each time I press a key on the Filco pad.
If you're going to be doing any serious degree of numpad-tapping though, I think the stability of the 'full' keyboard is beneficial. That is, if you don't have any requirements like needing to have it on the left hand side.
« Last Edit: Sun, 23 October 2011, 06:18:41 by arplod »
Offline nar
« Reply #4 on: Sun, 23 October 2011, 20:50:42 »
I might get the Filco, it seems to be relatively cheap on Amazon JP and I'm ordering something from there soon anyways.
I'd get a full keyboard, but I just really like this topre now and a full topre is quite expensive compared to this.
