Author Topic: "Laptop style" keycaps?  (Read 3856 times)
Offline impulsecss
« on: Fri, 21 October 2011, 10:35:02 »
Hey,
Weird request here, but I just recently starting using a mech (rosewill rk-9000 reds). Before making the switch I was a huge fan of scissor-type keyboard, having liked the low-travel, snap-response feel.
Well anyways, I kinda miss the keycaps most laptop-style keyboards have. You know, the shallow, wide, barely crenulated keycaps on most scissor-type boards. Anyone know where I can get a 104 key set that'll fit my rosewill?
Offline spolia optima
« Reply #1 on: Fri, 21 October 2011, 10:37:07 »
I also prefer them over the regular keycaps.
The G80-3800 will use wider keycaps I think
keyboards!
Offline impulsecss
« Reply #2 on: Fri, 21 October 2011, 13:03:43 »
so...you're telling me I bought the wrong keyboard :yell:
« Reply #3 on: Fri, 21 October 2011, 13:59:26 »
Quote from: impulsecss;436216
not necessarily. the g80-3800 (when it's available in the west) keycaps WILL fit your rosewill, save for the modifiers/spacebar.
keyboards!
Offline impulsecss
« Reply #4 on: Fri, 21 October 2011, 14:09:18 »
So, there's no custom manufacturer that can makes key sets in this style?
Offline flyball
« Reply #5 on: Fri, 21 October 2011, 14:09:57 »
it sounds like you should have bought a laptop style keyboard...
[SIGPIC][/SIGPIC]
« Reply #6 on: Fri, 21 October 2011, 14:11:55 »
Not sure.
I did learn a new word, "crenulated", all thanks to you!
keyboards!
Offline impulsecss
« Reply #7 on: Fri, 21 October 2011, 14:22:39 »
Quote from: spolia optima;436270
Not sure.
Glad I incremented your lexicon by one.
The search continues...
Offline Lethal Squirrel
  • I <3 60%
Offline impulsecss
« Reply #9 on: Fri, 21 October 2011, 20:01:39 »
Quote from: Lethal Squirrel;436407
Maybe you should look into the Cherry G84-4100
http://www.newegg.com/Product/Product.aspx?Item=N82E16823333078&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Keyboards-_-Cherry-_-23333078
Maybe I'll just buy it for the keycaps -_-
Offline pitashen
« Reply #10 on: Fri, 21 October 2011, 20:10:52 »
OP, do tell why you prefer "laptop style" keycaps. and are you talking about those macbook style keycaps?
Offline impulsecss
« Reply #11 on: Fri, 21 October 2011, 20:36:04 »
Quote from: pitashen;436443
I'm not. I meant the type that are on PC laptops. I did some digging around, and I guess they are called "low-profile" key caps.
  • I <3 60%
« Reply #12 on: Fri, 21 October 2011, 20:59:59 »
Quote from: impulsecss;436440
You can't use these keycaps on a Cherry MX keyboard. this board has cherry ML switches. they are a bit different. This is the only mechanical keyboard that I can think of with laptop style keys. I have one and It's pretty good. It was my favorite for a while until I got my first board with blues.
Offline False_Dmitry_II
« Reply #13 on: Fri, 21 October 2011, 21:30:22 »
I'd actually like to try one sometime, but that's sorta expensive to try one sometime. So I probably won't. What's with the super tiny spacebar on that one though?
Offline pitashen
« Reply #14 on: Fri, 21 October 2011, 21:34:17 »
Quote from: impulsecss;436448
So why do you like them?
For me the depth of the keycap actually gives more precision for typing. Fingers can register where the keys are better.
Offline Oqsy
« Reply #15 on: Fri, 21 October 2011, 22:19:11 »
Perhaps you need a set of cherry mx flat top relegendable keycaps and some rubber o-rings to reduce travel. That's the clsest you'll get to what you're after short of buying a lenovo keyboard.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
