Author Topic: Question abt brown and red switch.  (Read 2646 times)
Offline a1san
« on: Fri, 21 October 2011, 17:07:41 »
Hello there guys? how are you? (i hope and wish fine)
So , i had a crazy idea that wil cost abt 4 switches.
I have abt 10 spare cherry mx brown switches.
I was wondering if i open their caps and somehow i will remove the crosspoint(the inner iron-gold contact) i will have the feelings of the cherry mx reds right?
i mean the brown are  tactile cause they come in contact with the crosspoint, right?
So if i remove it and take it out ,the result will be a mx cherry red switch that will not be used as it will be destroyed ofc.
from the spring side red and browns they share the same sping,yes?
I want to stick them on a pcb and send them to a friend to check them before ordering a board with reds.
So what do you thing?
Offline daerid
    • Rossipedia
« Reply #1 on: Fri, 21 October 2011, 17:12:33 »
Look at the wiki. The browns are tactile because of the stem plastic itself. The actual crosspoint contacts on all Cherry MX switches are the same.
Brown:
Red:
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Fri, 21 October 2011, 17:18:33 »
No crosspoint means no switch.
Filco w/ Imsto thick PBT
Offline noodles256
  • le legendary
« Reply #3 on: Fri, 21 October 2011, 17:18:34 »
credits to lethul squirrel ^^^^
AF | Ducky YOTD |
Offline a1san
« Reply #4 on: Fri, 21 October 2011, 17:25:37 »
Thanks for the reply,apreciated!
I did check the wiki. The problem is that i dont own any red switches in order to make a test example to send them for sample...
The only switches i have are 10 mx brown switches.
I dont have a red plastic stem.
So if i open the cap of the brown switch, remove the crosspoint contact , and recap it ,then the brown stem will not have any contacts so it will be linear right? (though destroyed switch also)
So if my calculations are correct i will have a linear red switch just for sample .
Offline alaricljs
« Reply #5 on: Fri, 21 October 2011, 17:30:15 »
If you take the crosspoint out you will have a plastic plunger in a plastic housing and no switch.  It should FEEL like a red switch though.
Offline a1san
« Reply #6 on: Fri, 21 October 2011, 17:40:40 »
Quote from: alaricljs;436392
Thank you all i wanted to know!
i dont want a working switch , i just want to send him to try the red switches(modified browns) over his blue switches.
He wants to buy the Majestouch R 104 (cherry reds) and as the price is kinda high he asked me if i could send him a sample just for the feeling.
Thanks a lot all of you!
« Reply #7 on: Fri, 21 October 2011, 18:20:33 »
Alternatively, you should be able to shave off the bump on the brown switch. I would recommend this instead.
I think it's called ghetto red or something.
Offline Lethal Squirrel
  • I <3 60%
« Reply #8 on: Fri, 21 October 2011, 18:24:58 »
Lovely animations you have there ;)
« Last Edit: Fri, 21 October 2011, 18:28:50 by Lethal Squirrel »
Offline spolia optima
« Reply #9 on: Fri, 21 October 2011, 18:35:30 »
the most common way to do this is brown spring + black stem = ghetto red
but the way you described it should work too. Of course it won't be a working switch, but it should feel more or less like a red.
keyboards!
