Author Topic: Thermaltake Meka  (Read 3478 times)
Offline leotnnz
Thermaltake Meka
« on: Sat, 22 October 2011, 14:08:13 »
i am finding a tkl kb with numpad. tt meka seems the only choice for me, while i rocks 6230 discontinues.
i know tt meka g1 is from CST. which factory is this meka coming from? cst either?
and anyone owns this and any comments?
thx
Offline leotnnz
Thermaltake Meka
« Reply #1 on: Sat, 22 October 2011, 14:15:15 »
Quote from: ripster;436831
I'm still working on all the acronyms.
oops. the dude, what is the TKL?
Offline fantus
Thermaltake Meka
« Reply #2 on: Sat, 22 October 2011, 14:30:55 »
Doesn't Ten Key Less mean no numberpad?
Offline laffindude
Thermaltake Meka
« Reply #3 on: Sat, 22 October 2011, 14:36:38 »
Tenkeyless with numpad is indeed a oxymoron ;o
Not sure who's the OEM, but it is not Costar since it is made in China.
Cherry stabilizers, 6kro over USB, small backspace and BIG enter, / ? key in absurd location, construction looks cheap.
This board will definitely drive me nuts if I had to type on it. No thanks.
Some disassembled picture http://www.iqmore.idv.tw/tt-esports-meka-mechanical-gaming-keyboard-review/2
Offline insilica
  • Keyboard Geeza
Thermaltake Meka
« Reply #4 on: Sat, 22 October 2011, 14:38:36 »
Quote from: leotnnz;436829
thx
Confused! I guess I need to spend some more time here :)
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline ssshjp
Thermaltake Meka
« Reply #5 on: Sat, 22 October 2011, 14:59:42 »
Tenkeyless keyboard with numpad? That's a little confusing.
Do you mean 80% size with numpad
« Last Edit: Sat, 22 October 2011, 15:02:32 by ssshjp »
Offline leotnnz
Thermaltake Meka
« Reply #6 on: Sat, 22 October 2011, 15:05:52 »
Quote from: ssshjp;436854
oh, yeah. 80%with numpad is what i mean. sorry for misleading.
Offline pitashen
Thermaltake Meka
« Reply #7 on: Sat, 22 October 2011, 15:20:59 »
Quote from: leotnnz;436858
Lets do some math.
Standard extended keyboard layouts have about 109~112 keys. Time those by 0.8 (80%) you get, say for ANSI (US) layout, about 87 keys. Which is the number of keys you get from Tenkeyless.  That should clarify where the 80% came from. Therefore there is no such thing as 80% with numpad, coz that would end up not being 80%.
 With thermaltake meka, you are rather talking about a standard layout with "compact" form factor in general.
« Last Edit: Sat, 22 October 2011, 15:26:23 by pitashen »
Offline noodles256
  • le legendary
Thermaltake Meka
« Reply #8 on: Sat, 22 October 2011, 15:47:28 »
ping
AF | Ducky YOTD |
Offline pitashen
Thermaltake Meka
« Reply #9 on: Sat, 22 October 2011, 16:24:10 »
ping
Offline ssshjp
Thermaltake Meka
« Reply #10 on: Sat, 22 October 2011, 19:15:34 »
Puck In Net: Goal!
Anyway, compact form can be referred to the pattern of cherry G80-1865.
Approximate 80% size, it does make sense.
Offline pitashen
Thermaltake Meka
« Reply #11 on: Sat, 22 October 2011, 20:17:09 »
Quote from: ssshjp;437001
Puck In Net: Goal!
if you can provide some numbers with regard to the area reduction of 20% say G80-3000 vs G80-1865. It would be great.
Offline ssshjp
Thermaltake Meka
« Reply #12 on: Sat, 22 October 2011, 20:51:15 »
Well, I mean 80% does better describing the size of TT Meka than compact form, since compact form can be regarded as G80-1865 size, which is not small enough to reduce 20% size to standard 104.
Thermaltake Meka
« Reply #13 on: Sat, 22 October 2011, 21:09:44 »
Quote from: ripster;436908
Ping is an acronym for Packet INternet Groper.  I'm SERIOUS!
Yep: I use it frequently, too.
ping -c 10 http://www.google.com
'cause if google is down, you have bigger problems than your internet not working. :p
Why don't you get a tenkeyless keyboard (like the CMstorm) and add a tenkey-pad to it? There is a link to some $20 ALPS ones from ebay in the great finds section.
Offline dimoniy
Thermaltake Meka
« Reply #14 on: Sun, 23 October 2011, 14:39:43 »
If you want gaming keyboard, you better get meka G1. "Just meka" sucks IMO.
Tt eSPORTS MEKA G1 | Das S Pro Silent | Leopold FC500RR/AB
All of them full-size. I love my numpad!
