Author Topic: Odd keymap with Leo -10  (Read 1954 times)
Offline Jef
« on: Mon, 24 October 2011, 13:37:14 »
Firstly, thanks for all the guidance. After mostly lurking for a year, I just got a Leopold Tenkeyless with Blues, and I'm loving it.
However, using PaintShop Pro, when I try to save a file, certain letters trigger changes in the program rather than enter the letter, as if the 'control' key was permanently pressed. That is, if I try to save a file and name it "Drawing C", instead of "C", it opens/closes the color control window.
Just wondering if anyone else has encountered this, or even better, knows of a solution.
Thanks,
Jef
Offline Jef
« Reply #1 on: Sat, 29 October 2011, 11:40:21 »
Thanks for the suggestion. Naturally, I haven't been able to get it to do it again.
But if no one else has had this occur, then I can cross the keyboard off the list of suspects.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #2 on: Sat, 29 October 2011, 11:45:45 »
Are you running Windows? I've had it in this state before.  It's some kind of shortcut mode and I don't think it has anything to do with the keyboard per se.
Sadly I don't know how to get it back to normal short of rebooting.
Could it be that one of Paint Shop's hotkeys conflicts with the Windows hotkey to enter this mode?  Is the issue confined to within Paint Shop?
« Last Edit: Sat, 29 October 2011, 11:48:13 by hashbaz »
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #3 on: Sat, 29 October 2011, 11:47:30 »
Sounds like Sticky Keys, the windows mode that basically makes your modifiers toggle keys. Check to see if that's turned on, maybe?
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Bry
« Reply #4 on: Sat, 29 October 2011, 12:10:05 »
[ Attachment Invalid Or Does Not Exist ] 30317[/ATTACH]
last.fm | deviantART | SC2
Filco MJ2 Ninja - MX Red | Filco MJ2 Ninja - MX Brown | U9BLS - MX Brown
Offline Jef
« Reply #5 on: Thu, 03 November 2011, 14:44:25 »
Quote from: Bry;441819
(Attachment Link) 30317[/ATTACH]
:roll:
Thanks for the suggestions.
I've been using this same version of PSP for ten years, so I don't think it's the program. I would have bumbled into it by now. :biggrin1:
Sticky Keys sounds like a possibility.
