Author Topic: Topre Spacebar Size  (Read 6537 times)
Offline nigritude
Topre Spacebar Size
« on: Mon, 24 October 2011, 19:06:12 »
I just pre-ordered the keycap set for the Topre in blue. Is the spacebar for the 87 the same as the spacebar for the 86 or will I not be able to use the colored spacebar on my 86?
Also, if I have two keycap pullers, what is the best way to remove the spacebar? Are there any metal stabilizers I have to press down before pulling?
Offline reaper
Topre Spacebar Size
« Reply #1 on: Mon, 24 October 2011, 19:11:56 »
For the spacebar removal, Topre one is pretty easy compare to Filco/Costar.  I'd just remove the 2 keycaps next to the spacebar and gently lift it up.  Works perfectly everytime.  Good luck and let us know how it goes. =P
« Last Edit: Mon, 24 October 2011, 19:18:24 by reaper »
Din Eli
Offline suntorytime
Topre Spacebar Size
« Reply #2 on: Mon, 24 October 2011, 19:15:55 »
Unfortunately the spacebar will not fit properly as it will be too short on the 86U. To remove the spacebar just place one metal hinge on each end of the space and pull upwards, I can't recall if there are stabilizers, but if there are, they aren't like the cherry MX type. If you break it you can always go MacGyver on it.
Offline nigritude
Topre Spacebar Size
« Reply #3 on: Mon, 24 October 2011, 19:17:37 »
Thanks for the prompt replies! Guess I will just find out in a week whether that spacebar will be usable or not...
Offline reaper
Topre Spacebar Size
« Reply #4 on: Mon, 24 October 2011, 19:17:39 »
Quote from: suntorytime;438479
Thanks for the correction.  I've edited my post above and here's the picture of the spacebar:
There's no stabilizers, just that spring in the middle.
« Last Edit: Mon, 24 October 2011, 19:20:27 by reaper »
Din Eli
Offline jpm804
  • KeyCap Assasin
Topre Spacebar Size
« Reply #5 on: Mon, 24 October 2011, 19:25:35 »
Quote from: nigritude;438481
It will not fit like mentioned above since the spacebar is shorter on an 87u compared to the 86u
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline Kisakuku
Topre Spacebar Size
« Reply #6 on: Mon, 24 October 2011, 19:26:40 »
Offline nigritude
Topre Spacebar Size
« Reply #7 on: Mon, 24 October 2011, 19:37:27 »
Ah, I see. Thanks for the picture reaper and Kisakuku, that is very helpful.
« Last Edit: Mon, 24 October 2011, 19:41:00 by nigritude »
Offline reaper
Topre Spacebar Size
« Reply #8 on: Mon, 24 October 2011, 19:39:09 »
I thought it might come in handy for others...   and you're welcome. =)
Din Eli
Topre Spacebar Size
« Reply #9 on: Thu, 01 December 2011, 15:06:07 »
Quote from: reaper;438482
Old post, but it needs a correction: The stabilizer bar is inside the keyboard, underneath the top plate. The two switch-looking things are its attachments. I dunno if the space bar is stable enough without them, though.
