Author Topic: Cherry doubleshots and RIT dye  (Read 3266 times)
Offline Retox
« on: Tue, 25 October 2011, 10:42:11 »
I am plannig on sourcing a full set of white/whitish keycaps for a G80-1865 and then dying them with RIT dye. Hopefully they will all be doubleshot. Does anyone know how well these take dye?
QFR with ergo clears
fossala
  •  Guest
« Reply #1 on: Tue, 25 October 2011, 10:44:24 »
Be careful with abs keycaps they melt/warp easily.
Offline Retox
« Reply #2 on: Tue, 25 October 2011, 11:20:07 »
I don't think there is a set of white pbt keycaps that match the bizzzarre right shift on the g80-1865... correct me if i'm wrong.
fossala
  •  Guest
« Reply #3 on: Tue, 25 October 2011, 11:26:23 »
What about the compaq 11800 that's pbt with a smaller right shift.
Typing on one right now.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 25 October 2011, 11:42:21 »
Pretty sure shift is 2 unit, same as standard numpad 0. Well it is on my 11900, which is very similar.
More on topic, I am trying out some vegetable based dye that doesn't require heat right now. I'll let you know if it turns out.
« Last Edit: Tue, 25 October 2011, 11:47:49 by lysol »
fossala
  •  Guest
« Reply #5 on: Tue, 25 October 2011, 11:45:00 »
Yeah, sorry I didn't notice the small difference.
« Reply #6 on: Tue, 25 October 2011, 15:38:32 »
Well I can say the dye / ink did successfully stain the plastic, but it needs quite a soaking to achieve a deep color. Worked very well on the white, with no visible tinting on the black.
After rinsing the excess off, it does not appear to be transferring color at all after rubbing with white cloth. Now the only question is how long it will last.
Offline Retox
« Reply #7 on: Wed, 26 October 2011, 14:07:06 »
don't be shy about sharing the long term results, Lysol.
Also, quick unrelated question. Are the outer shells of model m keycaps pure PBT? you said in your "let's boil some keycaps" post that the old IBM keycaps are pure PBT. source
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #8 on: Wed, 26 October 2011, 14:18:54 »
The general wisdom from past dye threads is DO NOT DYE cases.  Their size and uneven thickness leads invariably to warping.  Many have had success painting them with vinyl spray however.
Offline hashbaz
  • Grand Ancient One
« Reply #9 on: Wed, 26 October 2011, 14:20:06 »
Quote from: lysol;439142
Details please!  Dying keycaps is what led me to geekhack in the first place.
fossala
  •  Guest
« Reply #10 on: Wed, 26 October 2011, 14:22:22 »
Use vinyl dye for your casing. I used VHT and it worked well.
« Reply #11 on: Wed, 26 October 2011, 15:38:27 »
I got it at the craft store. I'm not really sure what it's intended purpose is, but am assuming some printing application since it only comes in 4 colors CMYK. All the package says is organic vegetable dye and the color, made in India and the warning about not spilling it as it will stain. It comes in liquid form and has the consistency of artist ink. A 500ml bottle was like $3something. I got the magenta and it is really bright.
Since keycaps came out so nice I decided to attempt dying the body of my white Goldtouch keypad. That did not work very well at all. It came out very splotchy and uneven, so I guess I will just use my VHT on it to un-ugly it.
I'll get some photos posted at some point.
« Last Edit: Wed, 26 October 2011, 15:42:24 by lysol »
Offline hashbaz
  • Grand Ancient One
« Reply #12 on: Wed, 26 October 2011, 15:47:18 »
Excellent, thanks!
Offline Retox
« Reply #13 on: Wed, 26 October 2011, 22:39:18 »
Hahaha.... when I said outer shell I meant the part of the two piece keycap that has legends on it. The outer part of the two part system
I'm planning on using duplicolor vinyl/fabric for the case. Relax everyone, I has it under control.
« Reply #14 on: Mon, 31 October 2011, 11:51:02 »
These are my first 4 test keys. It seems they have had some reaction to the dye and leaves me to believe there must be something not quite 'organic' in it like acetone... the plastic seems to have gone smooth and lost all texture where dye came in contact.
[ Attachment Invalid Or Does Not Exist ] 30426[/ATTACH]
Offline hashbaz
  • Grand Ancient One
« Reply #15 on: Mon, 31 October 2011, 11:52:48 »
Interesting.  The legends took the color fantastically.
